Question about climate control
Old Aug 10, 2003 | 04:48 PM
ericcer's Avatar
ericcer
Default Question about climate control
I have a 96 with the climate control A/C. Is air suppose to come out the floor vents with most of the climate control panel selections?
Old Aug 11, 2003 | 11:16 AM
ericcer's Avatar
ericcer
Default Re: Question about climate control (ericcer)
and I thought this would be simple question...
Old Aug 11, 2003 | 12:00 PM
Steel Blue 91's Avatar
Steel Blue 91
It dosen't on my 91. Sounds like you may have a door that's haning open.
Old Aug 12, 2003 | 10:32 AM
tdock's Avatar
tdock
Not 100% sure, but I think the defroster might still throw some heat downstairs, so your tootsies stay warm in the winter time. But if the vents are not adjusting correctly, there is that vacuum diverter right above the gas pedal that applies vacuum to the vents to open and close them, has a vacuum source hose coming in and one going to each vent, but you almost have to stand on your head to see it.
Old Aug 12, 2003 | 11:03 AM
Bodhi's Avatar
Bodhi
Default Re: Question about climate control (tdock)
I remember reading on here that that is a sign of a potential vacuum leak somewhere....on LT1 I seem to remember it is usually under the passenger side fuel rail....a plastic vacuum connector that gets baked by the engine heat and developes a small leak....
Do a search on here for vacuum leaks and I'm sure you can find a better explanation than mine :lol:
[Modified by Bodhi, 11:03 AM 8/12/2003]
Old Aug 12, 2003 | 07:51 PM
1Patriot's Avatar
1Patriot
If you don't have a vacumn leak problem, then you will need a new or rebuilt AC Programmer. Had a similar problem late last summer and I finally fixed it last month. There was another member who found a problem in the programmers vacumn ports, might check that out. The programmer is on the inside firewall above the gas pedal; not easy to get to but is held in place by a single screw.
Good luck with the repair, The last detail has an expensive replacement for the AC Programmer if you find a need for one.
To Question about climate control
