(False?) Knocking on 85. Possible sources?
Old Aug 10, 2003 | 05:22 PM
DF's Avatar
DF
Default (False?) Knocking on 85. Possible sources?
I am getting knock warnings on my 85. They always seem to happen in the 2000-3000 RPM range. I have looked through the archives and read a lot of the posts on this subject and have tried the normal tricks. Extra wraps around the sensor, making sure it is torqued to spec. Torquing it less than spec. Replacing the sensor. Running injector cleaner though it. I am still getting knock warnings.
A lot of people seem to get false knock warnings in the 2000-3000 RPM range. I think that may be the case with mine as well. It doesn't sound like it is knocking but I am not 100% sure. I just don't know what to look for next. Right now I am about at witts end. :(
Old Aug 11, 2003 | 09:29 AM
DF's Avatar
DF
Default Re: (False?) Knocking on 85. Possible sources? (DF)
TTT
Old Aug 11, 2003 | 11:24 AM
C10 JDR's Avatar
C10 JDR
What do you mean by knock warnings? Is it throwing a code?
Old Aug 11, 2003 | 11:38 AM
DF's Avatar
DF
Default Re: (False?) Knocking on 85. Possible sources? (britvette)
Yeah, the standard code 43. The timing gets retarded and have a huge loss of power and milage.
Old Aug 11, 2003 | 02:33 PM
C10 JDR's Avatar
C10 JDR
First I would stick a timing light on there, check the timing is OK.
Assuming it is, a weak mixture could give you pre-ignition, or it could be genuinely false, like small ends, ring flutter, lifters, timing chain...oh dear...best check the timing first!
(genuinely false ??? Did I write that??? :confused:
Old Aug 11, 2003 | 05:47 PM
DF's Avatar
DF
Ok, I will try that first. I am going to have to find someone who knows what they are doing with that though :)
Old Aug 12, 2003 | 08:19 AM
C10 JDR's Avatar
C10 JDR
good luck!
Old Aug 12, 2003 | 03:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Have you checked the (ESM) electronic spark module? It could be faulty, too.
Old Aug 12, 2003 | 04:42 PM
DF's Avatar
DF
Default Re: (False?) Knocking on 85. Possible sources? (onedef92)
I believe I tested it a while back using the methods in the shop manual. I would have to double check on that and I don't have the manual here right now.
[Modified by DF, 2:43 PM 8/12/2003]
To (False?) Knocking on 85. Possible sources?
