(LT1) Oil Pressure dropping
Old Aug 10, 2003 | 07:50 PM
Bat Man's Avatar
Bat Man
Default (LT1) Oil Pressure dropping
I have an LT1, when I start up the car cold, the oil pressure is at the 3'rd line (3/4s to 80psi).
When it warms up to about 150 it starts to hang around the 2nd line (or half to 80).
When it gets up to about 210-220 oil temp, and I'm cruising it goes to about half way between the 2nd and 3rd line.
Some times off idle. It will kinda hesitate for a second and then the oil pressure goes to normal.
Whats up?
Old Aug 10, 2003 | 07:53 PM
vader86's Avatar
vader86
Default Re: (LT1) Oil Pressure dropping (Valleybacker)
I dont know your gauges on the LT1, but at startup it should be in the high 50s-60psi, after it gets hot the cruising pressure should be in the low/mid 50s, and idle pressure shouldnt drop below about 30-35psi.
If yours aint doing that, then replace the sending unit first, then replace the oil pump if that doesnt fix it. I had the same problem last month and it was the pump.
Old Aug 10, 2003 | 08:22 PM
Bat Man's Avatar
Bat Man
Default Re: (LT1) Oil Pressure dropping (vader86)
Nope, its doing that. I just wasn't sure if that was "proper"
Old Aug 11, 2003 | 07:58 AM
Atok's Avatar
Atok
Whats up?
If you're asking why it drops as it warms that's normal.
My '95 is similar except when cruising my oil temp is only 200 - 205 and the pressure is 38-45. That's in 6th gear at 70mph, 5th gear it's more like 45-50psi. My car was never abused, 40000 miles. 5w30 Mobile-1.
Old Aug 11, 2003 | 08:51 AM
Dave C. '04 Z06's Avatar
Dave C. '04 Z06
In my '95, the oil pressure is about 50-60psi when it's cold, but when it's warmed up all the way(~220' oil temp), at idle it's at the second line (20psi I think) and then at about 2000RPM it's at 40 (right in the middle).
-Dave
Old Aug 11, 2003 | 08:55 AM
mitchcole's Avatar
mitchcole
sounds perfectly normal :seeya
Old Aug 11, 2003 | 09:14 AM
pkvvette's Avatar
pkvvette
Default Re: (LT1) Oil Pressure dropping (mitchcole)
At cruising speed my '95 LT1 is 50lbs, 60 to 70 when I'm pushing her and about 35 at idle. Yours sounds a little low.
Old Aug 11, 2003 | 12:15 PM
Cal Vette's Avatar
Cal Vette
I own a92 LT1 it does the same thing, sounds perfectly normal ! :)
To (LT1) Oil Pressure dropping
