Noticed something odd while changing spark plugs
Old Aug 11, 2003 | 01:11 AM
383 Stroker's Avatar
383 Stroker
Default Noticed something odd while changing spark plugs
While I was changing plugs I noticed that directly under the area where the spark plug hole is there is a small somewhat dried-up trail of oil. It's on the passenger's side closest to the front of the car.
I have been eating up oil for a while now and it only seems to be worsened when I really stomp on the gas a lot. If I cruise around town without stomping on it, I lose hardly any oil at all.
Is it possible that this is where my oil eating problem is? Could oil leak from this area if the spark plug wasn't tightened properly?
Old Aug 11, 2003 | 01:18 AM
weekendwrench's Avatar
weekendwrench
Default Re: Noticed something odd while changing spark plugs (383 Stroker)
The oil is probably from valve cover gasket leak.
Old Aug 11, 2003 | 01:19 AM
weekendwrench
Do a compression test wet and dry to see if rings may be a possible cause of your oil consumption. Does the car smoke on start up after sitting overnight? Bad valve seals or guides can be the cause of that.
Old Aug 11, 2003 | 01:23 AM
383 Stroker
Default Re: Noticed something odd while changing spark plugs (weekendwrench)
Yep, I had my mechanic from Atlanta check the valve seals and he said they were bad and replaced them. Still eats oil after all that. He did compression testing as well and said it was satisfactory. The theory about the valve cover gaskets seems plausible but there isn't any leak down from that area. If it were coming from the valve cover seals wouldn't the oil trail be above and below the spark plug, not just below?
I've been fed up lately with the way she runs and I'm planning to send her out to Speed Works in TX to drop the engine, drop the compression ratio, slap on a ProCharger S/C, and everything else that will make her run the way she was meant to run without all the headaches.
[Modified by 383 Stroker, 12:25 AM 8/11/2003]
Old Aug 11, 2003 | 07:35 PM
offershore's Avatar
offershore
Remember what I said about cyl. wash?
To Noticed something odd while changing spark plugs
