Bigger valve cover problems ... help?
Old Aug 11, 2003 | 02:12 AM
396 Roadster's Avatar
396 Roadster
Default Bigger valve cover problems ... help?
I went to some bigger valve covers for my Brodix heads, and now the A/C compressor needed to be spaced out 3/4" on the bracket. Now I realized the stock belt won't fit. What size belt do I need? (1" longer?) Anyone know?
I also need to modify the wiper motor ... can anyone give me some tips? Pics?
Thanks.
Old Aug 11, 2003 | 02:17 AM
eguyett1985's Avatar
eguyett1985
Default Re: Bigger valve cover problems ... help? (396 Roadster)
I went through that awhile back on my 85 and on the wiper motor I had to trim the plastic cover and remove the washers between the motor and the firewall and it cleared...barely. On the A/C compressor though I didn't have any problems so I can't help you there. Good Luck
Old Aug 12, 2003 | 08:20 AM
396 Roadster
Default Re: Bigger valve cover problems ... help? (eguyett1985)
Anyone else have these problems when going to larger valve covers?
Do you have any pics of the modified wiper motor?
Old Aug 12, 2003 | 09:48 AM
Corvette0096's Avatar
Corvette0096
I had some custom made..
Old Aug 12, 2003 | 11:41 PM
396 Roadster
Default Re: Bigger valve cover problems ... help? (corvette0096)
I don't want to change my valve covers, I was hoping to just trim the plastic on my wiper motor. Anyone else do this mod?
What about the belt length?
Old Aug 12, 2003 | 11:54 PM
Corvette0096
There are a few rubber gromits that you can take of that will give you a little more room..3 total.
Old Aug 13, 2003 | 07:51 AM
396 Roadster
After removing the gromits and spacers, how do you trim the plastic wiper motor cover? Does it need to be recovered? Pics please?
[Modified by 396 Roadster, 5:51 AM 8/13/2003]
Old Aug 14, 2003 | 05:17 AM
396 Roadster
Come on forum members ... some of you must have bigger valve covers on your motors. I need some input please.
Old Aug 14, 2003 | 08:52 PM
jmr302's Avatar
jmr302
Previous owner modified my wipermotor by swinging a 500lb piece of iron at it. :jester
It's not very pretty.
Old Aug 15, 2003 | 04:32 AM
396 Roadster
Default Re: Bigger valve cover problems ... help? (jmr302)
I'm trying to stay away from the sledge hammer routine ... any other ideas?
Old Aug 15, 2003 | 01:30 PM
jmr302's Avatar
jmr302
Well if it's an emergency you could attack the corner of the wipermotor with a Dremel w/ a cutoff tool. You'd gain the clearance and the cut would be clean but it doesn't look that cool.
I don't know what your setup is but do you really NEED tall covers? I've got a one-piece seal block and heads in my car and I fit aluminum roller rockers with polylocks under some cast aluminum valvecovers. Seems to me a tall valvecover shouldn't be needed unless you're running girdles on the rocker studs. Just a thought.
To Bigger valve cover problems ... help?
