Pwr Steering Pump Fluid - 1985
Aug 11, 2003 | 07:52 PM
Am installing a new power steering pump and noticed some pre-lube coming from inside the pump as the common "red stuff" (I guess the same as the auto tranny fluid). I always thought our cars used the "clear" fluid thats proprietary GM power steering fluid. What do you use? TIA
[Modified by GRX, 8:55 AM 8/12/2003]
Aug 11, 2003 | 08:23 PM
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Pwr Steering Pump Fluid - 1985 (GRX)
:cheers: I use AMZOIL synthetic auto tranny fluid in all my power steering pumps. it stands up great to the heat and solved my morning sickness problems on my 88 :seeya
:steering:
Aug 11, 2003 | 11:38 PM
ttt
Aug 12, 2003 | 03:53 PM
Cruise-In VIII Veteran
Re: Pwr Steering Pump Fluid - 1985 (jackdaroofer)
:steering:
Ditto for Valvoline SynTec PS fluid. :thumbs:
Aug 12, 2003 | 04:03 PM
Re: Pwr Steering Pump Fluid - 1985 (onedef92)
Did you use the old "turkey baster" method of changing the fluid?
Aug 12, 2003 | 08:07 PM
Cruise-In I Veteran
Cruise-In V Veteran
Re: Pwr Steering Pump Fluid - 1985 (Southern Comfort)
:D Is there any other way? Drain it, refill it, start the engine and turn the wheel a few times, then drain and refill again
:seeya
:steering:
Aug 12, 2003 | 08:18 PM
:seeya Jack..you still pushin' that tranny fluid in the power steering ?... :p: :D
Aug 12, 2003 | 08:27 PM
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Quote:
:steering: Ditto for Valvoline SynTec PS fluid. :thumbs:
I'm using the same, and have trouble keeping it cool, it boils during hard driving.
But, I have Z51 and no power steering cooler..
Aug 12, 2003 | 08:31 PM
Cruise-In I Veteran
Cruise-In V Veteran
Re: Pwr Steering Pump Fluid - 1985 (CentralCoaster)
:D Power steering cooler is a cheap mod, it is nothing more than a piece of metal tubing in the return line running back and forth across the front of the frame.
:seeya
Aug 12, 2003 | 09:00 PM
Corvette Central has the cooler and the hose.
[Modified by GRX, 6:00 PM 8/12/2003]
Aug 12, 2003 | 09:01 PM
So no one uses the CLEAR GM pwr steering fluid?
Aug 13, 2003 | 07:34 AM
That's what's in mine now. The service bay flushed and filled it with it after they installed my new rack pipe a couple of months ago.
I mentioned the Valvoline SynTec as a cheaper, quality alternative. :thumbs:
Aug 13, 2003 | 07:35 AM
I have the FX-3 with the PS cooler so mine stays within temp paramaters. :thumbs:
