rear swaybar install
Old Aug 13, 2003 | 10:06 PM
larryfs's Avatar
larryfs
Default rear swaybar install
is it possible to install a rear bar without dropping the exhaust?
1996 LT4 Z51 car
removing 24mm installing 26mm rear bar.
thx
[Modified by larryfs, 3:13 AM 8/14/2003]
Old Aug 13, 2003 | 10:11 PM
ELEVENS's Avatar
ELEVENS
Default Re: rear swaybar install (larryfs)
What year car?
Old Aug 13, 2003 | 10:13 PM
larryfs's Avatar
larryfs
Default Re: rear swaybar install (ELEVENS)
96 as edited above.
Old Aug 13, 2003 | 10:26 PM
ELEVENS's Avatar
ELEVENS
No problem on my 1990. Just remove one rear tire to pull the bar out the side. But I don't carry a spare tire - maybe that has to be removed also?
[Modified by ELEVENS, 10:27 PM 8/13/2003]
Old Aug 13, 2003 | 10:28 PM
larryfs's Avatar
larryfs
I got the spare tire down. looks like the exhaust has to be dropped................................. ..................................
Old Aug 14, 2003 | 12:14 AM
No Go's Avatar
No Go
I installed my bar without touching the OEM exhaust.
Just don't install the bar upside down...you wouldn't be the first to do this...it will install incorrectly, but will handle very weird.
Old Aug 14, 2003 | 07:19 PM
silver & red CE's Avatar
silver & red CE
Default Re: rear swaybar install (No Go)
Me too, I did have to remove the spare tire and carrier. Never put the spare back on :cheers:
Eric
Old Aug 14, 2003 | 07:33 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: Getting the bar in and out is less of a hazzle if you drop the muffler end of the exhaust, no need to disconnect the Y Pipe
:seeya
:steering:
To rear swaybar install
