Here is another L98 cooling problem... My problem is not from the coolant temp but the oil temp run hot at RPM's over 2400. I have changed The EGR valve and solenoid. If anyone has any suggestions I would appreciate hearing from you.
The Oil Temps will run over 250 and will keep climbing to the point of lost oil pressuse. The coolant temps will follow up to 200 and hold steady. I have no problems at idle or city driving even at 100 degree weather.
Scorp508 posted something about oil temps a while back and someone suggested the sensor could be bad/corroded and sending wrong signals. Corrosion increases the resistance I guess. Check the sensor, I guess, but this wouldn't explain your loss of oil pressure... :confused:
Don't think corrosion would be the problem here. Temperature sensors decrease resistance as they get hotter so if you had corrosion and increased resistance you would get a lower than actual reading. Could still be a sensor problem though. Would not think that the oil could get that hot while the coolant appears to be OK.
Or could be the other way around, coolant is reading too low and engine is actually at 280 degrees and the oil temp would be reading about right. Sure hope that isn't the case.
Just a guess, but IF the oil pump was not pumping enough due to a pump problem, pick up clogged, or pick up not getting enough oil. Wouldn't that cause the pressure to be low AND because of the decreased flow cause the oil to heat up. The oil pan acts as a sort of radiator to cool the oil, if the oil is not being pumped at a sufficient rate wouldn't that cause it to over heat?? I have never actually seen this and this is just a guess at what could cause both symptoms.
What is the pressure when first getting under way and everything is cool?
When you crank, you get what oil pressure.
What is it after the oil temps get to say, 200F at idle and cruise.
What weight oil and brand.
how long does it take for temps to soar over 250 after you crank it, or is something else causing it that you can tell
So your pressure holds between 45-60psi and then suddenly drops to what after you hit 250F?
You shouldnt be hitting 250F anyway. Your thermostat may be stuck, and the space between the condensor and the radiator is clogged up. You cant clean that space without removing the shroud, nor can you see anything from underneath. You should also flush out the radiator.
@250 deg. is ok for your oil temp and your tstat will have little or no effect on your oil temp.I need those ? answered.
I don't know how high the oil temps got before I lost my oil pressure. I just know that the last time I notice the oil temp it was at 250. I can still get the oil temps up if I get the oil temp up to 250 if I just get on the freeway for a short trip. If the thermostat was stuck, my coolant temps would also be running hot. I have replaced the thermostat, removed the radiator and cleaned and check everything related to the cooling system. This is a mystery that will get solved. I thought that maybe someone out there might have had the same problem with the L98, so it would save me a lot of research.
250 oil temp is fine!!!!!!!!!!!!!! OUR OIL IS GOOD TIL 400 F
[Modified by offershore, 5:24 AM 8/15/2003] my car runs @211 - 220 oil temp @1800 rpm and 190 water temp. another 600 rpm to get up to 2400 is going to raise the oil temp even more 250 would not surprize me and the oil psi will drop then come back as the oil cools.
Offshore,
I hope you got your electricity back. If the 250 degree oil was just a once-in-the-while thing, I would not worry about it. There is something that is not right and this problem gets worst on a hot day. It was over 100 degree weather when I completely lost oil pressure.
And you think 250F is ok for an engine that is not race-ready, and hasnt even gotten over 2400rpm.
I'm sorry but thats not right. It should not be getting there, if the sensor is reading the correct data.
blackbeauty, have you replaced the oil temp sensor, or pressure sending unit yet. They would be the next thing to replace. If your pressure holds right now, then it probably isnt the oil pump
