Ecm code #43
Old Aug 15, 2003 | 08:21 AM
Corvette0096's Avatar
Corvette0096
Default Ecm code #43
I changed the knock sensor and wire for the sensor and I am still getting a code 43. But not right away. any ideas?
Tia
Rich
Old Aug 15, 2003 | 03:32 PM
LD85's Avatar
LD85
Default Re: Ecm code #43 (Corvette0096)
You did have a dark blue wire for the knock sensor, yes?
Old Aug 15, 2003 | 07:31 PM
VQT88Vette's Avatar
VQT88Vette
Default Re: Ecm code #43 (ld85)
What does the color of the wire has to do with transferring signal to ECM? I replaced my knock sensor and the wire plug from Jeff Kopp. The wire is white. I too have code 43 everytime the car under higher load
Old Aug 15, 2003 | 07:44 PM
Corvette0096
Default Re: Ecm code #43 (Oldman)
Did you clear the codes by disconnecting the battery for a few seconds?
:yesnod:
Old Aug 15, 2003 | 07:51 PM
Corvette0096
Found the problem.. The shrink wrap had some exposed wire and was grounding out.. :bb
To Ecm code #43
