Valve seals
Old Aug 17, 2003 | 06:58 AM
Sliding's Avatar
Sliding
Default Valve seals
I've been reading a lot of posts in archive and found many different
opinions on what valve seals should be installed.
This is a poll about lower seals only ( positive type, not umbrellas ), not the o-rings.
So, where do you have valve seals installed?
Old Aug 17, 2003 | 11:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Valve seals (Sliding)
My '88 (#113 heads) had both O-rings and lower seals on intake & exhaust so I got a set of each from my local Chevy dealer and installed all new seals on both int & exh.
However, I did toss the tin oil shedders that were on top of the stock springs.
[Modified by 65Z01, 11:17 AM 8/17/2003]
