Knock Sensor Question
Old Aug 18, 2003 | 03:06 PM
91superram's Avatar
91superram
Default Knock Sensor Question
I read a post stating that the knock sensor can be by-passed by disconnecting
the battery and unpluging the knock sensor then plugging the battery back up
and leaving the knock sensor disconnected.Will this work on my 91 L98, will this leave a code and do I still need to put a resistor in series to ground?
Old Aug 18, 2003 | 03:11 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Knock Sensor Question (91superram)
The ECM will check the knock sensor after each startup by advancing timing till ping is detected.
With the sensor disconnected the ECM should throw a code.
Old Aug 18, 2003 | 03:15 PM
91superram's Avatar
91superram
Default Re: Knock Sensor Question (65Z01)
Should put a resistor in series to ground and what size resistor should I use on my 91 L98
Old Aug 18, 2003 | 04:27 PM
CarAteMyMoney's Avatar
CarAteMyMoney
I only get codes occasionally when I'm accelerating hard, once out of every 10 or 15 times I floor it, that' s it. I havent had the sensor on since I bought the car (9 months ago)
Old Aug 18, 2003 | 05:16 PM
91superram's Avatar
91superram
Default Re: Knock Sensor Question (CarAteMyMoney)
Did you put a resistor to by-pass it or is it just disconnected
Old Aug 18, 2003 | 07:22 PM
65Z01's Avatar
65Z01
I don't see how you can bypass the knock sensor as it is a dynamic device.
If the ECM fails to see feedback when it tests the sensor it will set a code; if it sees constant knock feedback it will pull excessive timing.
Old Aug 18, 2003 | 08:12 PM
CarAteMyMoney
the wire for it is burnt, and just hanging there, not shorting with anything
Old Aug 18, 2003 | 09:03 PM
65Z01's Avatar
65Z01
Running without the knock sensor is putting the engine at risk.
The connector is the same as the aux fan switch connector and either can be purchased with a wire attached for around $16 from Contemporary Corvette (link on my site).
Old Aug 18, 2003 | 09:09 PM
larrybsp's Avatar
larrybsp
FYI the resistor method does not work. I've tried it. I even tried fooling the IAT sensor with a resistor and it didn't work. It does work on the water temp sensor though. The ECM looks for the specific frequency of knock for the specific engine. Putting in a resistor reduces the signal amplitude but does not have any effect on frequency. Believe me I learned a lot after I blew an engine by bypassing the knock sensor when I had a chip burned. :nopity :nopity :nopity Just being dumb.
To Knock Sensor Question
