tpi conversion
Old Aug 19, 2003 | 05:44 AM
aussie 84vette's Avatar
aussie 84vette
Default tpi conversion
im getting my engine re-built soon and i was wondering if its worth putting a tpi system on instead of the cfi.. what would i have to change? cpu, etc... and how much could i pick one up for roughly?
plus i can get the guy to put another cam in and i was told that the stock cpu wont allow the cam to run at its maximum capabilities, is this true? :confused:
Old Aug 19, 2003 | 08:08 AM
rodj's Avatar
rodj
Default Re: tpi conversion (aussie 84vette)
Vette Connection in Seaford (03 9773 5644 ) want A$1550 for a 85 TPI with no wiring or computer or $2150 for an 89 setup with every thing.
Pay up to US $500.00 on ebay but then you need to import it and pay freight and duty.
Here in Aust is probably more cost effecive to put a carb on.
Old Aug 19, 2003 | 10:37 AM
robertpel9's Avatar
robertpel9
Default Re: tpi conversion (rodj)
if you arent gonna mod it further just keep the X-fire. It is not as bad as people make it out to be. Its not worth the cash to upgrade to stock TPI set up. I have owned both trust me. A good running X-fire is a fine engine.
Old Aug 19, 2003 | 11:43 AM
vettek50's Avatar
vettek50
:iagree: go with carb and edelbrock manifold.. install one wicked cam and your away..if worried about cost. this setup could deveolped some serious H/P..good luck!
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Well, if you don't know about it already, try this site. You've got to register first but it's free and there's a wealth of info on the Crossfire and mods for it:
http://www.crossfire.homeip.net/cftest/startdefault.asp
Old Aug 20, 2003 | 02:31 AM
aussie 84vette
Default Re: tpi conversion (tobijohn)
yep i know about that site ta..
Old Aug 20, 2003 | 02:32 AM
aussie 84vette
Default Re: tpi conversion (vettek50)
cool ill look into that manifold. :cheers:
To tpi conversion
