Help! Idle problems return
Old Aug 19, 2003 | 09:57 AM
JJ 86's Avatar
JJ 86
Default Help! Idle problems return
Ok, for the last couple of weeks i've been having idle problems and now the car will not start at all. It will fire then immediatley die. I've cleaned the IAC valve, checked the MAF sensor, checked all the vaccum lines (found a couple of broken lines and replaced). I am completely out of ideas. It still does the same thing. So far nothing has worked. :banghead: Last month i put in a gm remain ecm could that be the problem.
:mad
Old Aug 19, 2003 | 10:12 AM
mk842766's Avatar
mk842766
Default Re: Help! Idle problems return (JJ 86)
Fuel Pump???? :crazy:
Old Aug 19, 2003 | 10:14 AM
BIG JIM 54's Avatar
BIG JIM 54
Fuel Filter?
Old Aug 19, 2003 | 10:15 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Help! Idle problems return (mk842766)
What is your oil pressure when it does fire up? AC on? Turn everything off.
Old Aug 19, 2003 | 10:21 AM
JJ 86's Avatar
JJ 86
I forgot to mention that i've replaced the fuel filter. Also the fuel pump was replace by the previous owner about 20,000 miles ago. The car has 110,000 miles on it. My problems began while driving in a bad rain storm last month and i 've been having problems since. I first thought it was water in the gas so i drained the tank and replaced the fuel filter. (didn't fix) Then i checked and cleaned the iac (didn't fix) found a broken vaccum line to the egr valve fixed that (problem still there) i also checked the maf sensor (probelm still there) All in all i'm on my last straw with this particular vette. :mad
Old Aug 19, 2003 | 10:26 AM
JJ 86's Avatar
JJ 86
Default Re: Help! Idle problems return (ski_dwn_it)
Oil pressure stays between 50 and 60psi when its cold then when its warm it'll stay around 40 to 45 at idle. Is that good?
Old Aug 19, 2003 | 01:16 PM
JJ 86's Avatar
JJ 86
TTT
To Help! Idle problems return
