Idle speed again
Old Aug 19, 2003 | 10:11 PM
87Vert's Avatar
87Vert
Default Idle speed again
My 87 is idling around 1200 but will back off to around 900-1000 after about 30 seconds (even when hot). I've replaced the intake manifold gasket, IAC, Oxygen sensor, EGR hose, EGR temp sensor, vacuum check valves, t, checked all obvious vacuum lines. What else could cause the thing to idle so high? I suspect I could have a problem with the vacuum lines at my AC programmer, but haven't felt like torturing myself again to go under there. I've looked in the archives, but can't seem to find any clues.
Old Aug 19, 2003 | 10:14 PM
redvette1986's Avatar
redvette1986
Default Re: Idle speed again (87Vert)
...a damp or otherwise bad TPS...mine does this high idle thing every year or so and it is always the tps...
Old Aug 19, 2003 | 10:52 PM
tequilaboy's Avatar
tequilaboy
The idle control has two operating modes, An open loop mode intended for cold start idle, which simply controls the IAC position as a function of coolant temperature. There is also a closed loop pid controlled idle which controls the idle rpm as a function of coolant temperature, with a typical setting of 500 rpm for normal coolant temps.
Most likely the throttle itself is open way too much, and the IAC cannot close-off enough to compensate properly. Get an OBD1 cable available from AKM electronics and others and run datamaster or EFIlive software to get a look inside at what's going on. Another option would be to build a simple 160 baud interface and use WinALDL software. You should be able to find lots of info in the Scan and Tune area once you get that far. The calibration of the MAF also plays a role with respect to mixture control and BLMs since there is only a limited range of self compensation.
In my experience it is nearly impossible to get a good idle when working blind, by just tweaking the throttle stop screw, and/or tps sensor, etc.
Old Aug 20, 2003 | 08:11 AM
ROCKY85's Avatar
ROCKY85
As I worked my way through all the issues inherited with the wifes 85, one thing on the forum made mine work properly. After numerous attemps to set the base idle, one of the senior members advised that during the procedure the ETS should be disconnected also. Well today because of this advise it's running great and I quit losing sleep and hair. Hope this helps!
ROCKY85
P.S. Still have alot of sensor issues but thats for another case of beer!
To Idle speed again
