LT-4 Knock Sensor
Old Aug 20, 2003 | 10:19 AM
vettmike's Avatar
vettmike
Default LT-4 Knock Sensor
Has anyone used a LT-4 Knock Sensor in a L-98?
Any problems?
vettmike
Old Aug 20, 2003 | 02:27 PM
clemsonvette's Avatar
clemsonvette
Default Re: LT-4 Knock Sensor (vettmike)
i have one on my car to try to cut back on knock counts and it seems to be working just fine.
Old Aug 20, 2003 | 03:47 PM
fiberglasscoffin's Avatar
fiberglasscoffin
i no you can not use a lt4 knock sensor in a lt1 unless it is a 96 (obd2) so im guessing you cant use it in a L98 if you are talking about the knock modual i no you can use them in the lt1s but i dont no about the L98 does it plug into the bottom of your computer?
Old Aug 20, 2003 | 05:15 PM
clemsonvette
Default Re: LT-4 Knock Sensor (fiberglasscoffin)
it plugs into the spot where the original was at. the lt-4 knock sensor is less sensitive since it was used on an engine with roller rockers which make a good bit more noise that factory.
Old Aug 20, 2003 | 05:23 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: LT-4 Knock Sensor (clemsonvette)
The knock sensor (plugs into block on bothsides above pan) is the same for LT1 vs. LT4. It is the knock module (also called ESC module) that is different, i.e the LT4 module interprets the knock sensor data different than the LT1 module does.
Old Aug 20, 2003 | 05:27 PM
clemsonvette
Default Re: LT-4 Knock Sensor (Lone Ranger)
very true, i forgot the differences in wording. the sensor is the same for all of them i think. basically all of gm's vehicles had the same sensor.
Old Aug 20, 2003 | 05:31 PM
Black'92's Avatar
Black'92
Where is the Knock Module on a 1992?
Old Aug 20, 2003 | 05:41 PM
kman0066's Avatar
kman0066
Default Re: LT-4 Knock Sensor (Black'92)
We(92-93) can't switch to the LT4 knock module, only the ODBII guys can. And there's is located in their Computer if my memory serves me correct.
Old Aug 20, 2003 | 08:14 PM
fiberglasscoffin
Default Re: LT-4 Knock Sensor (kman0066)
the knock sensors are not the same you can not switch them around unless you have a 96 lt1/lt4 the 96 is odb2 the 95 to 92 lt1s are odb1 they will not work with a lt4 knock sensor
Old Aug 20, 2003 | 08:15 PM
fiberglasscoffin
under your computer take off the bottom cover thats where it is on my 94
To LT-4 Knock Sensor
