under hood lights..
Old Aug 21, 2003 | 09:22 PM
1989redvette's Avatar
1989redvette
Default under hood lights..
what turns the under hood lights on and off?? my battery is draining and it seems that maybe these are stayin on...after the interior lights go out they are still on with the hood just cracked...does it have to be shut all the way?? i don't seem to see any switches ?? help :confused:
Old Aug 21, 2003 | 09:53 PM
oldjoe's Avatar
oldjoe
Default Re: under hood lights.. (1989redvette)
I don't know about your 89, but my 85 lights can be unplugged. I usually keep mine unplugged until I need them. Joe :chevy :chevy
Old Aug 21, 2003 | 09:58 PM
J Z06's Avatar
J Z06
There are little connectors near the turn signal light area. Un clip the one's for the hood when you want the hood up without draining the battery(shows/track etc).
Old Aug 21, 2003 | 10:00 PM
dbwade36's Avatar
dbwade36
OKay, I want to unplug my hood lights, one is broken anyways. How to I unplug them? at the source? or somewhere else?
Old Aug 21, 2003 | 10:17 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: under hood lights.. (dbwade36)
On the DS, just in front of the wheel well, there is a covered fuse holder. Pop the top and remove the 10amp fuse. This will disable the circuit for both lights.
Old Aug 21, 2003 | 10:27 PM
chaos on wheels's Avatar
chaos on wheels
The lights are controled by mercury switchs next to the bulbs. In the pic, the mercury switch is the little "can" just above the bulb.
Be careful taking the lens off, it's glass!
There is a black weatherpak connector in the front corner that connects the underhood lights to power. It's easy to unplug them there. In the following pic, you can see the green gasket of the unplugged weatherpak (driver's side). Similar on the passenger side.
Old Aug 21, 2003 | 10:47 PM
Mark L. Warner's Avatar
Mark L. Warner
mid-ameica sells a kit that allows you to install a switch to turn them on or off by yourself. It works great on my '88
Old Aug 21, 2003 | 10:50 PM
TA's Avatar
TA
Just follow the wiring from the light back to the connector and unhook :yesnod:
Old Aug 21, 2003 | 11:13 PM
1989redvette
Default Re: under hood lights.. (TA)
thanks guys :cheers: i don't really want to disconnect them i allready did that to keep the drain from occuring i wanna get tehm fixed and working right...though that kit with the switch from mad sounds cool...maybe i'll look into that :D
Old Aug 21, 2003 | 11:33 PM
black85vette's Avatar
black85vette
....did some one say be careful with the lense because its glass? mine are warped due to heat!! at what temp does glass melt at ? how could this have happened? ?
Old Aug 22, 2003 | 07:00 AM
TiIngot's Avatar
TiIngot
Default Re: under hood lights.. (black85vette)
My '96 are glass lens covers. Maybe they changed from plastic because of the heat problem. If you want more light there is a higher wattage bulb that fits in the sockets. Don't remember what the part number is. I also unplug the light wiring harness on the drivers side and remove the fuse. I keep it in the consol in case I need it for a night show.
Old Aug 22, 2003 | 09:27 AM
1989redvette
mine are glass as well in my 89 vert.. :smash:
To under hood lights..
