I installed a set of QA1 shock the other night in the front of the car.
My car after launching on the strip would bounce 2-4 times. This effectely was loading and unloadin the rear wheels and effection traction I believe.
I chose the QA1 shocks for one reason. Their adjustability. They offer 12 setting for different applications. Which for me was perfect.
I installed them in about a 1/2 hours or so, with no problems. The stock ones were all but completely shot. While they still moved apart by themselves, they had little or no resistance in the together position.
After installing the shocks I set them on setting 6, middle of the road for starters.
Man what a difference in the car! It felt like it was on rails compared to the floater feel its had. I knew for quite a while that the shocks were bad. And the rear ones equally as bad, so they are next.
Last night I cranked them up to 12 (stiffest) there is absolutely no roll to the car now and the feeling is spectacular.
I have not been to the strip yet with them which will either make or break the shocks for me. On a setting of 1 they act like 90/10 shocks. 10 percent resistance in the upward direction and 90 resistance downward. This will allow the spring to spring up, loading the rear wheels with weight, then the front will come down real slow as you make your way through the 1/4. One thing I noticed right away with the shocks while the car was up on the lift is the wheels "hang" MUCH lower with these shocks. Which probably mean no more baby wheelies :lolg: Or maybe it will make it better. Only one way to tell.
Thus far I am very pleased with the shocks and would recommend them to anyone that is into drag racing and street handling. I can only imagine what 1 on each corner of the car will feel like. But for now I am very impressed and feel much safer without the floater feel on the road.
Jesse, they are really not like 90/10s when set loose. Both compression and rebound are adjusted at the same time, so they are just loose when set to zero. They ARE also longer as you noted. put some grease on the shaft and see if they bottom out while street driving. Mine do when i have the rear raised and the big tires on. I only have about 1 1/2in of compression travel. However, my front spring is so stiff, i could throw the shocks away and the car still doesn't bounce. I had a similar problem with the rear (only worse), but i think it was because of my hybred setup (85 car, 93 rear). I had to make custom brackets for the rear to increase the travel. In all, i still really like them for their wide range of adjustability. Enjoy
Yes I should have probably cleared that up in my post. I guess what I was trying to say is the desired effect I am trying to get would be a 90/10 shock. But you are right I noticed the same resistance upward/downward.
But in comparison to my stock shocks that basically pull apart like butter and drop the from of the car like and an ugly stepchild, they are 100X better. And will/should eliminate the bounce, bounce bounce I get when the front hits back down.
I will have to check the compession on the shocks as you say.
:cheers: Good to hear. I have a set sitting in the garage ready to be installed some weekend when I get time. I'm looking primarily for autocross usages, althought then getting a good street settings as well (since its my daily driver in the summer).
I think Brian means setting them to zero (all the way counterclockwise). This is how i set my fronts at the track, however, like i mentioned above, my spring is very stiff on it's own. The rears i just keep at 5 or 6.....seems to provide a nice ride and work well at the track.
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Re: QA1 Shocks Report..... (ralph)
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Sounds like a great replacement for FX3 cars. Who makes them and where do you buy them. Looks as if this forum will give me a supercar and a slim wallet. :steering: :auto: :D
I've had mine for about 8 months now and love 'em! They work out great for Auto-X, you can " dial-in" the amount of stiffness you need for the track conditions. You can also adjust them for a heck of a smooth ride for cruisin...best of both worlds. :cheers:
I just got my fronts on last night, took a ride today. They feel great. Road to work on 5, felt super smooth, went to 12 for the ride back, felt amazingly tight. Best investment I have ever made. Can't wait until I get the rears on.
