how much can i handle
Old Aug 22, 2003 | 12:46 PM
ENGINE TROOP's Avatar
ENGINE TROOP
Default how much can i handle
hello all
i have a stock 86 coupe i was considering nos
can it handle it ?
how much ?
oh yea iron heads and a 700r4
soon i will replace the trans with a new rebuilt unit :flag
Old Aug 22, 2003 | 01:02 PM
BAM92's Avatar
BAM92
Default Re: how much can i handle (perryroger86vette)
Depends alot on miles and condition of your motor. But I would guess you could run a 100 hp dry shot through it.
Old Aug 22, 2003 | 01:11 PM
krivera's Avatar
krivera
Default Re: how much can i handle (BAM92)
yep run a 100 shot should be fine if you took care of your motor the tranny will be the first to go~!
Old Aug 22, 2003 | 01:17 PM
scorp508's Avatar
scorp508
100 wet shot.
Old Aug 22, 2003 | 03:27 PM
ENGINE TROOP
Default Re: (scorp508)
have 30000 miles i am thinking wet is best
i have ran into a 125 wet shot for 300 is this a good deal
what else do i need? guage?
the trans now is toast i am in the process of getting a new one. any advise on what trans to use for nos? :chevy :chevy :chevy
[Modified by perryroger86vette, 8:47 PM 8/22/2003]
Old Aug 22, 2003 | 05:39 PM
fiberglasscoffin's Avatar
fiberglasscoffin
100 wet shot.
:iagree: wet
Old Aug 22, 2003 | 05:48 PM
azzkikr's Avatar
azzkikr
i've got an adjustable 75hp to 300hp wet system, i've got it jetted for 100hp shot, which i believe in reality is only about 80hp. at 100 shot i'm told... my car's computer can adjust for timing, fuel etc. without having to upgrade fuel supply or ignition & timing. just don't expect 'fast & furious" stick-to-the-back of-your-seat power. once you go above 100-125hp of nitrous you have to start building the motor & car for it. make sure you do your homework, wide-open throttle switch and never use under 2,000rpm
have fun & good luck!
Old Aug 22, 2003 | 11:41 PM
fiberglasscoffin
Default Re: how much can i handle (azzkikr)
also i put in a msd 6al box a new msd coil and a rpm window switch ngktr6 plugs one step colder and msd wires and with the 100 shot you do feel it
To how much can i handle
