Canton oil pans
Old Aug 25, 2003 | 07:20 PM
superlund's Avatar
superlund
Default Re: Canton oil pans (luvmy92)
I think so...last time I looked over on the Z28 forum they were still having the problem. I used an expensive (1) piece urethane pan gasket & reused the factory oil pan stiffening rails. I had to modify/clearance the pass side stiffening rail to clear the formed divot in the pan for the dipstick tube. Mine doesn’t leak but many have. Also if you purchase one, remove the trap doors & clean the inside out with some thinner. Mine was brand new directly fron Canton & it was full of crud left over from manufacturing.
Old Aug 26, 2003 | 07:11 AM
luvmy92's Avatar
luvmy92
Default Re: Canton oil pans (superlund)
Thanks, Jim! I will probably be ordering one in the next week or so. I think I'll print this thread for safe keeping as well. :thumbs:
Mike
