[pa] brake upgrade question
Old Aug 23, 2003 | 08:46 PM
85autoxr's Avatar
85autoxr
Default [pa] brake upgrade question
if i have all four calipers and rotors off of a 99 vette can i put them on my 85 if so any brackets needed where to get them? thanks :cool:
Old Aug 24, 2003 | 12:37 AM
DON M's Avatar
DON M
Default Re: [pa] brake upgrade question (85autoxr)
http://www.electro-dynamics.com/
This link will put you on their web site. There are others on the Forum that have the adaptors cheaper, but I used these about a year ago. they are well made and good people to deal with.
You will be pleased with the cost/value ratio for this conversion and the braking performance is fantastic.
Search the archives as this subject has been beat to death.
Old Aug 24, 2003 | 07:17 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: [pa] brake upgrade question (DON M)
:iagree: C5 upgrade is awesome
Electro dynamics is high on their adapters. Just do the front brakes, the rears are basically similar to C4, plus you could have emergency brake problems with C5's
You might want to install DRM Brake proportioning spring to bring the rear brakes into play
:D :seeya
:steering:
Old Aug 24, 2003 | 08:26 PM
85autoxr's Avatar
85autoxr
Default Re: [pa] brake upgrade question (jackdaroofer)
any idea on prices for adapters? :cool:
Old Aug 24, 2003 | 11:29 PM
92TripleBlack's Avatar
92TripleBlack
They vary by car year, front, rear, and polished or not. Mine were $275+/-. The whole setup was under $750 for front with red Z06 brakes, rotors, and hawk pads. I also went for the polished brackets. The C4 has better rear brakes so stick with those. Just paint them red.
Old Aug 24, 2003 | 11:43 PM
Corvette0096's Avatar
Corvette0096
I just did this swap a couple months bacl on my 85. I went here for the adapters.
http://www.car-vette.com/hot.html
and went here for the rest of the stuff.
http://www.superchevyperformance.com/misc/c5brakes.asp
I am having the stock rears powder coated this week..
To [pa] brake upgrade question
