Brake ?????? Need help.
Old Aug 25, 2003 | 01:13 AM
NicBig's Avatar
NicBig
Default Brake ?????? Need help.
With the motor running, I press the brake pedal down 1/2 inch and I hear a air whistleing sound. Maybe vac. leak? Sometimes the brakes feel normal, next time I might need to push harder than normal. Braking assist failing or vac. leak??? Any ideas? I've had this 87 about 4 weeks and it's my first C-4. :banghead:
Old Aug 25, 2003 | 04:32 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Brake ?????? Need help. (NicBig)
It sure sounds like the booster, or possibly a leak in the vacuum line to it.
Old Aug 25, 2003 | 07:15 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Brake ?????? Need help. (65Z01)
:iagree: I would bet on failing booster, but definitely checkr the vacuum hose leading to it...might be smart to replace it now...if it is the booster you will want to replace it anyway
I try to put hose clamps on both ends of my booster vacuum line, just to be sure
:seeya
:steering:
[Modified by jackdaroofer, 7:17 PM 8/25/2003]
Old Aug 25, 2003 | 07:17 PM
NicBig's Avatar
NicBig
Thanks, I'm hoping its the line but I'm new to having a C-4 so I wanted a 2nd opinion before I became to involved.
To Brake ?????? Need help.
