horn relay?
Old Aug 25, 2003 | 01:40 PM
bops90's Avatar
bops90
Default horn relay?
I have a 90 coupe,I blew the fuse and replaced it and the horns worked for a while. Now all i get is a sound like they are getting juice, but not blowing. If i pull the wire off either side the other will blow.Could it be the relay? Thanks
Old Aug 25, 2003 | 08:22 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: horn relay? (bops90)
ttt
Man that's wierd :confused:
Old Aug 25, 2003 | 09:58 PM
jimswhite92's Avatar
jimswhite92
I'd check the voltage. 1st with both horns attached then with one horn attached. Report back.
Old Aug 25, 2003 | 11:03 PM
bops90's Avatar
bops90
Thanks Jim im going to check the voltage out in the AM. Mark
To horn relay?
