timming
Old Aug 25, 2003 | 04:49 PM
jtfrog's Avatar
jtfrog
Default timming
I know the timming on an 86 L98 is -6 btdc. I have read post on changing it to -4 or -2. By doing this are you advancing the timming or retarding it. One more thing. set timming in park or drive with est dissconected
Old Aug 25, 2003 | 04:55 PM
MrJay's Avatar
MrJay
Default Re: timming (jtfrog)
If you change the timing to 4 BTDC or 2 BTDC then you are retarting the timing because the computer will fire later but if you got to 8 BTDC or 10 BTDC then you are advancing the timing....you should have the car in park and est dissconected.
Jay
[Modified by MrJay, 9:52 AM 8/26/2003]
Old Aug 25, 2003 | 04:57 PM
FSTRNU's Avatar
FSTRNU
Default Re: timming (MrJay)
:lolg: :rofl:
Old Aug 25, 2003 | 05:46 PM
vvv90's Avatar
vvv90
Default Re: timming (FSTRNU)
TIM-MING!
Old Aug 25, 2003 | 06:25 PM
jtfrog's Avatar
jtfrog
WTF This is going to sound nuts but I can not locate the timming mark. Even with the EST disconected. Car is running great with new plugs HELP :rant:
Old Aug 25, 2003 | 10:25 PM
Sam Lam's Avatar
Sam Lam
jtfrog: I run my 89 L98 at 8 degrees before top dead center (BTDC) of the #1 piston. The spec from the "General" is 6 degrees BTDC. Not sure about the -6 etc mentioned in above posts???? I get good throttle response with this timing setting and the TPS set at .65 volts. Make sure you unplug the timing connector before you make the timing adjustment. Hope this is helpful!
Old Aug 25, 2003 | 10:40 PM
FD2BLK's Avatar
FD2BLK
As far as the timing mark goes with the motor off look at the balancer and find the grove then take somthing (white chalk or a silver sharpe) and mark it. After you mark it start the car and check it it should show up clear as day. For what its worth if it is running fine mark down what the timing is at now before you adjust it for a referance then adjust it and if it runs worse put it back where you found it. The other alternative is to leave it alone.
Old Aug 25, 2003 | 11:10 PM
86_Vette's Avatar
86_Vette
Default Re: timming (ejfagala)
Mine is set to 9. I was told you can bump it up as high as 12 if you want.
Old Aug 26, 2003 | 01:02 AM
jtfrog's Avatar
jtfrog
Default Re: timming (vvv90)
found the problem, the harmonic balancer slipped
Old Aug 26, 2003 | 01:10 AM
Corvette0096's Avatar
Corvette0096
Happens alot.. "pesssssssssst" It's spelled "Timing" :)
Old Aug 26, 2003 | 05:20 AM
jtfrog's Avatar
jtfrog
Default Re: timming (Corvette0096)
Sounds like it, The corvette care shop in Sacramento says its a common problem.
To timming
