I was having a look through the archieves as I need new wheel bearings, however I need to import them as I live in Australia. I was reading that the Timken bearing have worked out well for many people....I was looking at some aftermarket bearings and have noticed that some do not contain the cog used for the ABS system. Can anyone confirm that these Timken bearings do have these cogs or not?
I'm not sure but if your year has the cogs and timkens list that year than i would assume that theirs would have cogs also. I'm not sure which year they changed but i'm sure someone will chime in.
Good Luck
:cheers:
all the rear bearings are the same, but I do believe that the fronts should all have something for the ABS on them, even though there is 2 different front bearings (84-87 and 88-96)
