1993 - SES code 64 vs. SES code 44?!? any difference?
Old Aug 26, 2003 | 05:33 PM
Z06_BluByU's Avatar
Z06_BluByU
Default 1993 - SES code 64 vs. SES code 44?!? any difference?
whats the difference? they are both indicators of a lean exhaust?!? 64 says right bank and 44 doesnt specifiy.. does that mean left bank? :(
Old Aug 26, 2003 | 05:52 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: 1993 - SES code 64 vs. SES code 44?!? any difference? (BluByU)
Right and a left bank.
Old Aug 27, 2003 | 05:53 AM
vetteseniorcit's Avatar
vetteseniorcit
Both codes are indicative of a bad oxygen sensor. Check wiring and connectors at oxygen sensor (44). (64) Check wiring and and connectors from O/S to ECM. Check ECM ground; battery ground. Most of us don't have the ability to check fuel pressure, but troubleshooting calls for that, given the symptoms. The sensor provides the ECM with data for engine performance. The sensors are easy to replace, but the cost will probably be in the $80-$100 range.
To 1993 - SES code 64 vs. SES code 44?!? any difference?
