bottle heaters
Old Aug 26, 2003 | 07:52 PM
fiberglasscoffin's Avatar
fiberglasscoffin
Default bottle heaters
bottle heaters whos got them and which is the best?any pics?what kind of pressure do you get with them?
Old Aug 26, 2003 | 09:07 PM
AS84's Avatar
AS84
Default Re: bottle heaters (fiberglasscoffin)
1200 psi before purge on an NX heater. I threw my NOS heater in the garage....maybe I'll use it this winter to keep my dog's water from freezing.....but I'm not sure it will even work for that. The most it would do on a full bottle was 900 psi.
Old Aug 26, 2003 | 09:12 PM
fiberglasscoffin
Default Re: bottle heaters (AS84)
whats it heat controled?
Old Aug 27, 2003 | 03:50 PM
VetteNoob's Avatar
VetteNoob
I have the one from Dynotune.org. It is bottle pressure controlled much like the NX one and is much cheaper. Havent tested it since it's been pretty hot here in Texas in the summer.
Old Aug 27, 2003 | 10:48 PM
fiberglasscoffin
Default Re: bottle heaters (VetteNoob)
150 pretty cheap x2=300 that sucks isint better to get something not temp controlled cant you keep the pressure higher then with more heat say around 1000psi
Old Aug 28, 2003 | 05:54 PM
AS84's Avatar
AS84
My isn't on a pressure controlled system. I just wired the pad to a switch. The pad will only set you back $115. May not be the best system but it works for me and the bottle is dedicated only to track use.
Old Aug 29, 2003 | 10:21 PM
Dan Parker '96's Avatar
Dan Parker '96
I've got the Dynotune setup and have used it several times. It's quite good.
It's a big pad, comes with a relay and a (necessary) 20amp fuse.
Here's a pic...
Old Aug 30, 2003 | 11:34 AM
fiberglasscoffin
Default Re: bottle heaters (Dan Parker '96)
you only heat 1 bottle?
Old Aug 30, 2003 | 01:04 PM
Dan Parker '96
Yup. I don't have the bottles cross connected (only use one at a time). Plus there would be a hell of an amperage draw if you ran two bottle heaters at once. The alternator is taxed enough on these Vettes as it is.
Old Aug 30, 2003 | 01:07 PM
fiberglasscoffin
how come only one bottle at a time?with both togetter dont keep the pressure higher longer
Old Aug 30, 2003 | 03:00 PM
MasterDave's Avatar
MasterDave
Moderator
I have the NOS bottle heater and it stops the bottle right at 900 psi. According to my reading on the subject 900 psi is optimum. Sumthin' else I should know?
Old Sep 2, 2003 | 03:01 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: bottle heaters (MasterDave)
900 is minimum, 950-1000 is optimal. I run the NX heater as well.
Old Sep 2, 2003 | 04:01 PM
fiberglasscoffin
Default Re: bottle heaters (Vette92)
does your nx heater keep it around 900 or higher 1000?
Old Sep 2, 2003 | 04:36 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
From my understanding the NX transducer will regulate the pressure to between 950 and 1050. When I use the heater and allow it time to heat the bottle fully, it will stick close to 975-1000psi as I recall. I do not use the heater much so I may be a little off. I generally only need it in the colder months anyway or when the bottle starts getting low.
Chris
Old Sep 2, 2003 | 05:11 PM
scorp508's Avatar
scorp508
Chris I'm pretty sure you got it right. It heats up until it sees 1050 and then turns off until 950 then on till 1050 over and over.
Old Sep 2, 2003 | 07:23 PM
fiberglasscoffin
Default Re: bottle heaters (scorp508)
ok thanx im going to look into getting 2 nx bottle heaters
To bottle heaters
