Ford 24# injectors???
Old Sep 2, 2003 | 11:54 AM
FD2BLK's Avatar
FD2BLK
Default Ford 24# injectors???
Will the ford 24# injectors work in a LT1? The injectors are the ones with the blue cap if that helps.
Old Sep 2, 2003 | 03:18 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Ford 24# injectors??? (ejfagala)
Here's a TTT for ya.
And a little more info.
I have them in my L98. I put them in a couple of montghhs ago.
PERFECT replacement for the stock injectors in that application.
Now... does anyone know if LT1 injectors will fit an L98?
If they do then the Ford injectors will fit an LT1.
Old Sep 2, 2003 | 03:19 PM
scorp508's Avatar
scorp508
L98 injecotrs will fit LT1 injectors will fit LS1 injectors will fit LS6 injectors.
Old Sep 2, 2003 | 03:36 PM
FD2BLK's Avatar
FD2BLK
Default Re: Ford 24# injectors??? (VetNutJim)
Thanks for the info.
Did they work with the stock regulator?
Old Sep 2, 2003 | 04:38 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Good to know... need to follow this one.... :confused:
Old Sep 2, 2003 | 05:01 PM
RedyGo's Avatar
RedyGo
yes. they work awesome, way better than gm but they are rated a little differently due to different fuel pressures anyway a ford 24# is more like a 25#.
Old Sep 2, 2003 | 05:03 PM
vader86's Avatar
vader86
which of the injectors offered at fiveomotorsports are everyone going with? they had like 3 different 24lb injectors listed and i thought 2 of them said they would work with the Mustang, i didnt know which ones to order :confused:
Old Sep 2, 2003 | 06:57 PM
BAM92's Avatar
BAM92
Default Re: Ford 24# injectors??? (vader86)
Use the ones that go on the 5 liter mustangs.
Old Sep 2, 2003 | 07:05 PM
LaVidaLoca's Avatar
LaVidaLoca
Just call the guys at FiveOMotorsports. I found them to be very helpful. They can assist you with your selection. I bought a set of injectors for my 85 (not the 24# Ford) and was very pleased. They shipped same day and got here in 3 days. Sometimes the website does not have complete information so if you call you will get all the applications for the injectors they have.
Old Sep 2, 2003 | 07:33 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
I have a set for sale, slightly used (maybe 10 or 15,000 miles)
Ford Motorsport 24# injectors. New from summit approx. $220,
make offer.
To Ford 24# injectors???
