Filter Housing Broke
Old Sep 1, 2003 | 05:55 PM
HapAFcop's Avatar
HapAFcop
Default Filter Housing Broke (UPDATE)
I was going thru my weekly preventative maintenance routine today and lifted the hood and found my filter lid hanging half off. The tab on the side of the filter housing snapped off. Last weekend I cleaned the K&N and it seemed fine.
Has this happened to anyone else. Is there a quick fix?
I'm trying JB Weld right now. If that doesn't work, I think I'm going to duct tape the friggin thing on there.
I checked Mid America for a new filter housing: $64.99. Does that sound reasonable or is there some place cheaper?
thanks, Dave
[Modified by HapAFcop, 6:30 PM 9/2/2003]
Old Sep 1, 2003 | 06:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Filter Housing Broke (HapAFcop)
Try Contemporary Corvette (link on my site); they have a large Vette bone yard in Eastern PA as well as vend new parts.
Old Sep 1, 2003 | 06:19 PM
HapAFcop's Avatar
HapAFcop
Default Re: Filter Housing Broke (65Z01)
GREAT WEBSITE, 65Z01, but I can't find the link for Contemporary Corvettes.
Old Sep 1, 2003 | 06:27 PM
65Z01's Avatar
65Z01
Thanks, it was the 4th entry under "Service Sites"; here it is: http://www.contemporarycorvette.com/
Old Sep 1, 2003 | 06:31 PM
scorp508's Avatar
scorp508
You mean it hadn't broke yet? Consider yourself lucky. :)
Old Sep 1, 2003 | 06:32 PM
JCAIRE2's Avatar
JCAIRE2
Order a used one from vette2vette.com It's $65 for a new one no matter where you go. The plastic gets old and brittle. Doubt you'll be able to make it work , but good luck.
Old Sep 1, 2003 | 06:33 PM
VetteNoob's Avatar
VetteNoob
Broke mine too. Temp fixed it with Magnum Steel (same stuff as JB Weld).
Old Sep 1, 2003 | 06:58 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Had the same problem. I tapped a hole into a piece of aluminum and riveted it to the plastic, Ain't pretty but it works. Someday i'll replace the base. :smash:
:cheers:
Old Sep 1, 2003 | 10:22 PM
Shark ssn591's Avatar
Shark ssn591
Ecklers is about $59,
Corvette Central $54,
How do I know....
just bought one for my '88, broke during the caravan... made temporary repairs with the handy dandy electricians tape...
ordered from Corvetter Central on Sunday night... was at my door Tuesday when I got home from work.
I was thinking of the JB weld bond.. will do it to the old one (as a spare)
:steering:
Old Sep 2, 2003 | 09:12 AM
Rich B.'s Avatar
Rich B.
Default Re: Filter Housing Broke (AGENT 86)
I tapped a hole into a piece of aluminum and riveted it to the plastic...
Same here, with sheet steel. Used a reinforcing piece on the inside, long rivets through both outside & inside plates. I should have put polyester resin in the mix as well...
...There's always next time... :D :rolleyes: :thumbs:
Old Sep 2, 2003 | 07:42 PM
HapAFcop's Avatar
HapAFcop
Default Re: Filter Housing Broke (Rich B.)
I tried 2 applications of JB Weld and both times it came apart when I tightened down the filter lid.
I ended up using my dremel to cut a piece of sheet metal and attached it to the filter housing. However, the filter does not appear to completely seal now; so, this is going to have to be temporary.
My new question is: should I get a new housing from vette2vette delivered for $65 or a used one from a local yard (High Performance Salvage) for $50. I can pick up the used one at my liesure; however it is a bit out of the way.
I e-mailed the guy from High Performance Salvage to try and get him to come down on the price, because I'm local and own two (C4 & F-Body) of the cars he specializes in (future business).
Thanks for any advice,
Dave
To Filter Housing Broke
