Found 1985 Hood Struts for $16
Old Aug 28, 2003 | 02:08 PM
LD85's Avatar
LD85
Default Re: Found 1985 Hood Struts for $16 (Southern Comfort)
My 85 still has the scissor, but the gas shocks push the hood up higher than the scissor engagement point so I have to push the scissor forward to make sure it would catch if the hood every did try to come down.
What I am saying is the these shocks push the hood "up" as far as the extended scissor mechanism will allow it to travel.
Old Aug 28, 2003 | 06:26 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Found 1985 Hood Struts for $16 (85vet)
Thanks for the part #'s. I found the struts at autoparts.com for 14.81 each. Same info as autozone only less expensive!!!!
2- 95056 RNB ; [Lift Support] Mighty Lift; Gas Charged; Hood $14.81each $29.63 Total
of course plus shipping
:cheers:
jim did you order me 2 two? :cheers: :lurk:
Old Aug 28, 2003 | 08:28 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Found 1985 Hood Struts for $16 (CORKVETTE1)
No problem, I was going to give you a call.
Old Aug 28, 2003 | 08:29 PM
85vet's Avatar
85vet
Cruise-In V Veteran
is this in addition to the big strut or do you still have the scissors on the pass side.
Still have scissor on pass side.
Old Aug 29, 2003 | 06:05 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VII Veteran
Default Re: Found 1985 Hood Struts for $16 (ld85)
Larry, if you do go with the gas charged hood support, you may find you have too much lift. When they first went to the gas charged supports they eliminated the assist cylinder on the opposite side. So if you get the gas charged support, it will mount on the driver's side (which will also be more convienient for you scissor guys) and you will remove the assist rod near the passenger side hood hinge. Look here:
http://www.btinternet.com/~ray_quayl...d_hospital.pdf
for a paper I wrote a few years ago with some info on this.
Old Aug 29, 2003 | 07:45 AM
LD85's Avatar
LD85
Default Re: Found 1985 Hood Struts for $16 (Ray Quayle)
Thanks Ray, this is probabaly the next step.
Old Aug 29, 2003 | 12:09 PM
Southern Comfort's Avatar
Southern Comfort
be carful with that scissors....lol mine collapsed and the hood fell on my head. I replaced it with the upgrade strut and I still have the two little ones...(dead) I wonder if it would help at all to replace those too....for 17 bucks its maybe worth a shot.
Old Aug 29, 2003 | 12:12 PM
LD85's Avatar
LD85
With scissor replacement, does you hood go up easy from flat to 45 degrees?
I guarantee you that from 45 degrees to the top takes almost no effort.
Old Aug 29, 2003 | 12:27 PM
Southern Comfort
Oh yes ....the strut on the drivers side makes it effortless..But I was thinking the other two would help save the big one some effort. And me of course :yesnod:
Old Aug 29, 2003 | 02:28 PM
vettek50's Avatar
vettek50
replaced my stuts a few minutes ago <87>...shows some improvement!! part# 4003..strong arm gas charged<..still sourcing the main strut, which is spring asisted. no hinge...<89's> have gas and were the replacement..for the earlier models...anyone know that part#
Old Aug 30, 2003 | 10:41 AM
Corvette0096's Avatar
Corvette0096
Can someone take a picture of this?
Old Aug 30, 2003 | 11:34 AM
LD85's Avatar
LD85
Default Re: Found 1985 Hood Struts for $16 (vettek50)
1989 Hood Strut - Mighty Lift, Coupe Autozone
Part # A95250 $60
Or
http://www.expressautoparts.com/stor...tegory=SHOCAMS
[Modified by ld85, 11:38 AM 8/30/2003]
Old Aug 30, 2003 | 10:42 PM
  #33
CFI-EFI's Avatar
CFI-EFI
Mine takes me and @ 6 bikini clad women, so needless to say, I dont open my hood often! :lolg:
If that were the case with my car, I'd have the hood hinges worn out by now. "Hey! Girls! Lets check the oil, again!"
Good tip. I NEED a pair of those assist cylinders. Good luck, and...
RACE ON!!!
Old Aug 31, 2003 | 01:23 PM
  #34
Vette Head's Avatar
Vette Head
I did this too about a month or 2 ago. Noticeable difference from +45*. What I think we are all hoping for, is a hood that 'pops' open. It's my understanding that adjusting the springs at the hood latch will do this. Haven't done it yet 'cuz I don't have a wrench big enough. Anyone know how big that dang adjusting nut is? It's huge!
By the way, I got my struts at Carquest or Napa for $15 each.
Kirk :seeya
Old Sep 1, 2003 | 01:53 AM
  #35
MtlSphere's Avatar
MtlSphere
What was the NAPA part #?
:seeya
Old Sep 1, 2003 | 08:00 PM
  #36
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Found 1985 Hood Struts for $16 (MtlSphere)
NAPA part # 819-5311
Works like a different/new hood :cheers:
[Modified by 85vet, 8:01 PM 9/1/2003]
Old Sep 1, 2003 | 08:29 PM
  #37
Corvette0096
Anyone have a picture of this on there car?
To Found 1985 Hood Struts for $16
Old Sep 2, 2003 | 03:54 AM
  #38
MtlSphere's Avatar
MtlSphere
819-5311 does not appear to be a good number according to Napaonline.com.
I'll call them tomorrow or stop by to see if they are in stock locally. :seeya
Old Sep 2, 2003 | 03:02 PM
  #39
85vet's Avatar
85vet
Cruise-In V Veteran
The invoice shows 819-5311 and yes Napa online does not except it.
Try 8195311 and you will access the part :yesnod:
Looks like store numbers and online are a little different.
Old Sep 2, 2003 | 03:15 PM
  #40
GRX's Avatar
GRX
I'll keep my scissors style lift! :D Its a good workout! :lol:
