re allignment?
Old Aug 27, 2003 | 06:47 PM
Clemson Vette's Avatar
Clemson Vette
Default re allignment?
if i install a camber brace do i need to get my car aligned? what about if i lower the car? alignment again?
Old Aug 27, 2003 | 06:50 PM
dbwade36's Avatar
dbwade36
Default Re: re allignment? (Clemson Vette)
I would opt to realign the car if I made any changes to the suspension. 4 wheel alignment. I had it done when I changed tire size, but that one is obvious. Better safe than sorry. The thought of unnessasarily wearing out $350 tires that can't be rotated makes me cringe.
Old Aug 27, 2003 | 07:08 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: re allignment? (dbwade36)
You can rotate directional tires. Front to back on the same side. After doing that a couple times, you can have the tires from the left side mounted on the rims from the right side and vice-versa.
Old Aug 27, 2003 | 07:12 PM
dbwade36's Avatar
dbwade36
Default Re: re allignment? (JCAIRE2)
True, but I don't think I want to put my 18's on the front and 17's on the rear. DOH!
Old Aug 27, 2003 | 09:19 PM
vader86's Avatar
vader86
Yes, get it aligned. It will now hold the alignment you set even better.
To re allignment?
