Starting Problems
Old Aug 28, 2003 | 09:56 AM
Last716bblRR's Avatar
Last716bblRR
Cruising
Default Starting Problems
I'm having a problem starting my 1987 Vette with 36000 miles. This is intermittent, but sometimes when I go to start the car it trys to start, almost catches, but it won't actually start. It acts exactly like the car is flooded. When I am having the problem, I have to hold the gas pedal down half way and when or if the car starts, I have to let the car run at high RPM for 2 seconds to clean itself out and then the car runs perfectly. It can sometimes take 5 - 10 times to get the car to start when I am having this problem.
When I was down in Bowling Green when this problem was preventing me from getting the car started, I took it to Tech Tune to troubleshoot this. They unplugged my Cold Start Injector and this appeared to immediately resolve the problem. The car ran perfect after that for 2 months and now with the injector still unplugged, the problem is back. He also ran an emissions test on the car and it passed with CA standards (which I think would rule out a leaking injector).
The thing about this problem is that when it happens, the car can be cold or it can be warm. Sometimes I have it after filling up a tank of gas. After I hold the pedal down for 2 seconds to clean the engine out, it runs perfect. Idles like new.
Any ideas on where to go with this?
Old Aug 28, 2003 | 11:40 AM
jfb's Avatar
jfb
Default Re: Starting Problems (Last716bblRR)
It's possible that you have the original injectors that weren't replaced under a tech bulletin and they are leaking causing hard starts. Put a fuel pressure gauge on the shrader valve on the fuel injection rear and turn on the ignition for 2+ seconds and turn it off. See how long the fuel pressure holds up. GM says you should not lose 1 psi in 30 minutes or you have leaky injectors.
Old Aug 28, 2003 | 11:55 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Starting Problems (jfb)
jfb: Have 87 also, not having any problems, but wondering were i can get a copy of the tech replacement bulletin on the injectors?
Old Aug 28, 2003 | 12:16 PM
jfb's Avatar
jfb
Default Re: Starting Problems (daddvi)
I don't know how to access the service bulletin. There probably is a web site with them available. Maybe a CFer can help out here.
Old Aug 30, 2003 | 04:33 PM
Tvette98's Avatar
Tvette98
I believe you can find the service bulletins at this link...
http://www.c4vettes.com/svc_bull_launch.htm
To Starting Problems
