Transgo Shift Kit installed... very please with results.
Old Aug 28, 2003 | 07:27 PM
dbwade36's Avatar
dbwade36
Default Transgo Shift Kit installed... very please with results.
Well, the Kit is in & I must say, I love the way my Auto 86 vette shifts now. I like the firm shifts I now have. Also, added a Transgo performance 3-4 shift valve (damn those things cost $80). I hated having to drive around town in D, then upshift to OD. Now, I can leave it in OD in town and it doesn't try to jump from 2nd to OD. The shift points are at higher RPM's and it really "feels" like a sports car now. That being said, I can now safely move on to my engine mods.
Old Aug 28, 2003 | 08:45 PM
Wheelman's Avatar
Wheelman
Default Re: Transgo Shift Kit installed... very please with results. (dbwade36)
I haven't yet heard about the transgo 3-4 shift valve. Do you have any additional information or links on this product and how it operates??
Old Aug 28, 2003 | 08:51 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Transgo Shift Kit installed... very please with results. (Wheelman)
:iagree:
Old Aug 28, 2003 | 08:58 PM
dbwade36's Avatar
dbwade36
Only the info from "Mr Shift" , I will quote the following, as I am no expert in this area. " With Type 1 Valve Body the 3-4 shift will not be delayed above 1/2 throtle nor will it have passing gear at high speed from 4th to 3rd. The high throttle 3-4 shift is manually controlled with the shift lever. So when you do not want 4th, place the lever in "3rd" - HERE IS THE KEY!!! WITH TYPE 1 Valve Body- If you want a later high throttle 3-4 upshift or higher speed 4-3 downshift, install TRANSGO 7-4-VL special 3-4 shift valve. Hope this helps
Old Aug 29, 2003 | 12:43 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There is nothing like a good shift kit to make a C4 drive like a real performance machine. I especially love the 1-2 chirp and even a little "wiggle" on the upshift near WOT. :cheers:
Old Aug 29, 2003 | 07:12 AM
C10 JDR's Avatar
C10 JDR
Default Re: Transgo Shift Kit installed... very please with results. (65Z01)
Oh my God! Something else I didn't know I desperately needed :smash:
Old Aug 29, 2003 | 08:45 AM
hngacurv's Avatar
hngacurv
Default Re: Transgo Shift Kit installed... very please with results. (britvette)
My vette has a TransGo kit. I love the quick crisp shifts.
Old Aug 29, 2003 | 09:05 AM
Steel Blue 91's Avatar
Steel Blue 91
:iagree:
That's one of the reasons I hate this place!!!!! j/k:D So many things that I didn't know I needed!
Old Aug 29, 2003 | 09:07 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
:cheers: enjoy....
Old Aug 29, 2003 | 10:48 AM
86shark's Avatar
86shark
How much $ if you don't mind me asking and where did yopu get it?
Thanks :thumbs:
Old Aug 29, 2003 | 01:41 PM
dbwade36's Avatar
dbwade36
Default Re: Transgo Shift Kit installed... very please with results. (86shark)
Okay, here is the cost break-down. (pls sit down for this). $120 for the Transgo Kit, $80 for the 3-4 shift vavle, new "separator plate?" not sure if that is the correct term $20. Int/Rev Valave and Boost valve/sleeve upgrade $15. Total cost in parts: $235. plus 2.5 hours labor. Total cost around $450. I know that sounds like a lot, but I feel it was $$ well spent. I just love the way it shifts now. Very hard/firm shifts at higher RPM's. No lugging down or jump from 2nd to OD in town. I can't believe the difference. Now, if only I had some more HP! hehe
Old Aug 29, 2003 | 08:24 PM
cprgmr's Avatar
cprgmr
:thumbs: TransGo rocks! :D
To Transgo Shift Kit installed... very please with results.
