Gears?
Old Aug 30, 2003 | 11:27 PM
Epyon127's Avatar
Epyon127
Default Gears?
is there any way to calculate the speed and RPM effects of changing the rear gear in a 92 M6?
Old Aug 31, 2003 | 12:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Gears? (Epyon127)
There sure is, for example if I replace my stock 2.59s with say 3.54s my tach will read 1.367 times higher (3.54/2.59) for any given speed.
Further top speed in any gear will be reduced by the same ratio.
Old Aug 31, 2003 | 01:23 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Look for a program called "Chase gear selector" I downloaded it from vette92, you plug in tire size and gear ratio and it shows you what you need to know.
Old Aug 31, 2003 | 01:28 AM
Mr Mojo's Avatar
Mr Mojo
I just emailed you the program, let me know how it works out.
Old Sep 1, 2003 | 05:25 PM
mike.burke's Avatar
mike.burke
I have a 92 6spd and put 411's raised the RPMs 302 at 70 mph. There is a calculator at http://www.ring-pinion.com.
Old Sep 1, 2003 | 05:52 PM
dbwade36's Avatar
dbwade36
Default Re: Gears? (mike.burke)
MJ- can you email that program to me? Or if you don't mind, just tell me what my actual speed is based on 3.54 gears (86 auto) w/ 275/40/18's on rear and 17's on front? ie- If speedo says I am doing 70 MPH, isn't it something more like 65 MPH?
If my dash says 70 MPH now, I am right at 2k RPM's.
Old Sep 1, 2003 | 06:31 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: Gears? (65Z01)
Here's a good one but if your trans isn't in the lsit you'll need to know the internal ratios, plus 6th gear ratio:
http://www.dalesplace.com/htm/inform...calculator.htm
According to the this calc, when I plug in the ratios for the 4L60E and my rear tire size (OEM) It shows that rpms should be 1759 @ 75mph for a 2.59 rear, and 2085rpm @75 for 3.07 gears. Now, I have 2.59's according to my RPO sticker *but* my tach shows spot-on 2000rpm in OD locked-up @ 75mph!
Is there the ratio stamped on the outside of the differential within view? I need to check. Otherwise I guess I need to jack it and in neutral spin the rear tires and count drive shaft revolutions per tire revolution :crazy:
To Gears?
