SES light???
Old Sep 1, 2003 | 10:54 PM
JF_AH_64's Avatar
JF_AH_64
Default SES light???
I got a SES light twice in the past week, but now it doesn't come on anymore, is the code stored or must the light be on at the time of the scan. Thanks
Old Sep 2, 2003 | 03:41 AM
MtlSphere's Avatar
MtlSphere
Default Re: SES light??? (JF_AH_64)
If you haven't disconnected the battery...it's still in there.
Did the light go out while you were still driving or did it just not come back on the next time you started the car?
In any event the code is stored. Autozone offers to read codes as a service. Give'em a visit.
I'll bet code 32...any takers?
:seeya
Old Sep 2, 2003 | 03:51 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: SES light??? (MtlSphere)
:seeya
And you'll find that code offer depends on the make and model of your Vette. Some stores will be glad to to the old paper clip trick and others will tell you they can only read 94-96 OBD ECM's.
BTW, if it does turn out to be Code 32, you can pretty much ignore it, OR replace the EGR switch if the light bugs you.
Old Sep 2, 2003 | 04:25 PM
John Row's Avatar
John Row
Pulling codes on a 94 is a piece of cake. You probably have history codes still stored.
See this site for a good how-to http://www.c4vettes.com/codes.htm Use a big paperclip bent in a "U" to short the sockets.
You can scroll through the codes using the "ENG/MET-MILEAGE", "GAUGES-TRIP-ODO" keys.
I keep a bent paper clip in the center console.
[Modified by John Row, 1:26 PM 9/2/2003]
[Modified by John Row, 1:31 PM 9/2/2003]
Old Sep 2, 2003 | 04:31 PM
fiberglasscoffin's Avatar
fiberglasscoffin
i changed my battery it went away someone told me it had to do with your battery when i had that flash up a few times
Old Sep 2, 2003 | 07:39 PM
ittlfly's Avatar
ittlfly
Default Re: SES light??? (fiberglasscoffin)
I think you are refering to a flashing "SYS" code for battery problems.......not a DIC SES code.
Old Sep 2, 2003 | 07:45 PM
fiberglasscoffin
Default Re: SES light??? (ittlfly)
your right sys sorry for wrong info
Old Sep 2, 2003 | 08:13 PM
JF_AH_64's Avatar
JF_AH_64
Ok thanks for all the great info, I pulled the codes and I got:
C12, H26, H78
I searched the archives and I gathered that c12 isn't really a problem but what about the other two?
To SES light???
