1989 convertible passenger window
Old Sep 2, 2003 | 04:38 PM
C4-ME's Avatar
C4-ME
3rd Gear
Default 1989 convertible passenger window
The right side passenger window will not close, is there a check list? Does the window motor wear out? Does the switch fail often?Where should I start?
Old Sep 2, 2003 | 05:57 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: 1989 convertible passenger window (C4-ME)
Yeah the motors can go bad. I would start at the connector at the motor. Check for voltage there first plus ive seen corroded connectors that just needed a cleaning. If you dont get power at motor check the circuit breakers. Write back if you need more assistance. :smash:
Old Sep 2, 2003 | 08:42 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Try this!
Slam the door and then hit the switch to raise or lower, if it works, it's likely the switch
If it doesn't, it's likely the motor.
Jack
To 1989 convertible passenger window
