coil replacement?
Old Sep 3, 2003 | 02:11 PM
JJ 86's Avatar
JJ 86
Default coil ?
if the coil is bad would you still have spark?
could it cause the car not to start?
[Modified by JJ 86, 7:12 PM 9/3/2003]
[Modified by JJ 86, 7:22 PM 9/3/2003]
Old Sep 3, 2003 | 02:24 PM
scorp508's Avatar
scorp508
Default Re: coil ? (JJ 86)
Failing coil = weak spark
Dead coil = no spark
Old Sep 3, 2003 | 02:27 PM
JJ 86's Avatar
JJ 86
Default Re: coil ? (scorp508)
if the spark was weak would it still start and run bad or would it not start at all?
Old Sep 3, 2003 | 02:34 PM
scorp508's Avatar
scorp508
It could start and run pretty poorly and then die under any throttle. What sort of symptoms are you seeing?
Old Sep 3, 2003 | 03:18 PM
JJ 86's Avatar
JJ 86
It started up and ran for a couple of minutes then died. No codes or anything. All it does now is crank but doesn't even try to start. New fuel pump, fuel filter, cap, rotor, ingnition module, and plug wires. :banghead:
Old Sep 4, 2003 | 02:24 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Replace with the intrnal MSD coil. Fits inside of the distributor cap.
Availablem from Jegs, or Summit.
Go for it.
tony
Old Sep 4, 2003 | 02:30 AM
oldace84's Avatar
oldace84
Lost it.
tony
Help.
To coil replacement?
