[LT4]Rear gear fluid check
Old Sep 4, 2003 | 11:31 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default [LT4]Rear gear fluid check
If I wanted to check the oil level in the rear gears, do I have to drop the exhaust to get to the fill plug?? :confused:
Old Sep 4, 2003 | 11:34 PM
scorp508's Avatar
scorp508
Don't have to on my '87.
Old Sep 5, 2003 | 08:49 AM
silver & red CE's Avatar
silver & red CE
Default Re: [LT4]Rear gear fluid check (eamador11)
Or my 96.
Old Sep 5, 2003 | 09:16 AM
GS919's Avatar
GS919
Fill plug is located on the passenger side near the top of the rear end unit. No need to drop the exhaust. Should be full to the top of the hole. If you are unsure of the age of the fluid, I would recommend changing it. :steering:
Old Sep 5, 2003 | 10:01 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
Default Re: [LT4]Rear gear fluid check (GS919)
Thanks guys for your replies, now to lay on my back..... :crazy:
To [LT4]Rear gear fluid check
