Piston fire sequence ?
Old Sep 10, 2003 | 04:50 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: Piston fire sequence ? (Curveit)
The 4-stroke cycle might be easier to remember as..... Suck-Squeeze-Bang and Blow. I learned that as a kid. :D
Hmm. That reminds me of a girl I knew a few years ago. :yesnod: :D
Old Sep 10, 2003 | 05:15 AM
CentralCoaster
Default Re: Piston fire sequence ? (neverendingproject)
The firing order for the Gen.III smallblock and the 2001 8.1 liter (496 cubic inch) big block is 1-8-7-2-6-5-4-3. Eight individual ignition coils are computer controlled. No conventional distributor is used. The new firing order smooths out the running motor and eliminates the previous problem of the #5 and #7 cylinders firing right next to one another and causing fuel and air distribution problems.
:bs :bs
This firing sequence is actually the same. It is an exact mirror image (front to back) of the standard 18436572 firing order. When you flip it front to back, cylinder 7 becomes cylinder 1. (And of course, the number 1 cylinder is arbitrary, only the order matters.) If ANY advantage, it would be that the two cylinders next to each other in order are now 3 and 1. And it's probably easier to feed #1 a little extra air to make up for what #3 is stealing from it, since #1 is at the front of the intake manifold, and the first one inline in the plenum.
18436572 mirrored front to back= 72654318
Now reorder that sequence, putting the one in front... 18726543... tada!
1-8-7-3-6-5-4-2 gives the actual 10hp gain & also stated that reliability is increased.
Now this IS a genuine firing order. It still has 4 & 2 firing next to each other, but changes the balance of the crank by swapping firing of 4 and 7. It would use the same crankshaft still though.
[Modified by CentralCoaster, 2:32 AM 9/10/2003]
