Piston fire sequence ?
Old Sep 5, 2003 | 10:04 AM
TheStef's Avatar
TheStef
Default Piston fire sequence ?
Hi, I've been reading a lot about V8 small blocks about performance and upgrades, rebuilts and such, but I still have one question unanswered.
How does the fire sequence of the pistons occur?
Example, do the pistons fire one after the other from 1 to 8 or something more iradic like 2,3,5,8,7,6,1,4.... or do the pistons fire 2 at a time or just 1 at a time.
I'm trying to understand exactly why a stock V8 engine would be stronger then a stock 4 cyl or 6 cyl.
Thanks for any reply or explanation
Old Sep 5, 2003 | 10:11 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Piston fire sequence ? (TheStef)
Ok, the firing order for any SBC is 18436572
The pistons are numbered from the front of the block, counting towards the rear. The passenger side is even 2,4,6,8 the driver's side is 1,3,5,7 :cheers:
BTW, no two pistons fire at the exact time. Also when one piston is at TDC on it's compression stroke another is at TDC on it's exhaust stroke. The reason a V-8 is so smooth is it's naturally balanced design. There are 2 cylinders placed every 90 degrees around the crank. This leads to very balanced pressures and forces being applied to it.
[Modified by Nathan Plemons, 9:13 AM 9/5/2003]
OleDog's Avatar
OleDog
1-8-4-3-6-5-7-2
1357 drivers side
2468 pass side
Old Sep 5, 2003 | 10:15 AM
Nathan Plemons
This might help too
Old Sep 5, 2003 | 11:33 AM
Corvette0096's Avatar
Corvette0096
Default Re: Piston fire sequence ? (Nathan Plemons)
This might help too
:lol:
Old Sep 5, 2003 | 11:38 AM
scorp508's Avatar
scorp508
Well to a point. You've still got those pistons at the TDC BDC spots at differnent locations in the engine. It isn't like they are on the same crank journal. Something like an I6 or a V12 is even smoother.
Old Sep 5, 2003 | 12:49 PM
TheStef's Avatar
TheStef
Default Re: Piston fire sequence ? (scorp508)
Cool image! thats what I wanted to see, but was expecting to imagine it in my mind :)
What does TDC meen? I've seen this term before, but can't remember what it meens? and what about BDC?
I can tell the way the V8 is moving that its really smouth, but how does the 4 stroke work exactly.. can someone explain to me the 4 steps the piston, valves, go through to create energy?
Old Sep 5, 2003 | 01:11 PM
Nathan Plemons
TDC - Top Dead Center - Piston is at it's highest point
BDC - Bottom Dead Center - piston is at it's lowest point
How does a four stroke cycle work... well I could explain it but this will probably be faster and it has more illustrations anyway. This is just one awesome website http://auto.howstuffworks.com/engine.htm
:cheers:
Old Sep 5, 2003 | 01:42 PM
scorp508's Avatar
scorp508
Thats a kickass link!
Old Sep 5, 2003 | 04:51 PM
C10 JDR's Avatar
C10 JDR
I think Gen III Small blocks are 1-8-7-2-6-5-4-3 (after about 1997)
Old Sep 5, 2003 | 04:56 PM
scorp508's Avatar
scorp508
Default Re: Piston fire sequence ? (britvette)
Yep, started with the LS1. From Mortec.com....
The new Gen.III "LS1" motors have a different firing order than previous smallblocks. The firing order for the Gen.III smallblock and the 2001 8.1 liter (496 cubic inch) big block is 1-8-7-2-6-5-4-3. Eight individual ignition coils are computer controlled. No conventional distributor is used. The new firing order smooths out the running motor and eliminates the previous problem of the #5 and #7 cylinders firing right next to one another and causing fuel and air distribution problems. In case you were wondering, the firing order for the Gen.I, II and previous "Vortec" motors is 1-8-4-3-6-5-7-2.
Old Sep 5, 2003 | 05:00 PM
-=Jeff=-'s Avatar
-=Jeff=-
I also heard that you could essentially get a cam set uyp for the LS1 firing order for use int he Gen1 and Gen 2 blocks, but I don't know how true that is or if it will work
Old Sep 5, 2003 | 05:05 PM
C10 JDR's Avatar
C10 JDR
I suppose if you had a cam ground, and swapped the plug wires round, our motors could be 18726543. Wonder if there is a real advantage. It was OK the old way for about 150 years, or however long the Chev V8 has been alive, on the other hand they thought it was worth doing for the LS1..... :confused:
Sorry Jeff we were posting at the same time! :)
[Modified by britvette, 11:06 PM 9/5/2003]
Old Sep 5, 2003 | 05:10 PM
Nathan Plemons
Thing is if you actually draw it on paper it doesn't look like a huge deal.
In the original you have 2 cylinders fire on the same bank twice. Once when you go 5/7 and once when it goes 8/4. In the new design this only happens once, on the 2/6.
So it seems to me that this would actually be more unbalanced. As it sits with the original design you have a two cylinders that fire right after each other on each bank. In the new design only one bank does this. The only thing it really does is keeps two cylinders from firing directly next to each other but how much of a problem is that really?
Old Sep 5, 2003 | 06:35 PM
C10 JDR's Avatar
C10 JDR
- and if you understand that the allocation of a particular number to a particular cylider is arbitrary, it may be even less of a deal - but nevertheless The General thought it was worth doing. Maybe it was. On the other hand ......
Old Sep 6, 2003 | 05:25 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Stef,
To address your second question: a V8 is stronger (if by stronger you mean more powerful), because a V8 is USUALLY larger (more displacement) than a four or a six.
Even if you had two engines with the same displacement, say a six and an eight, the engine with more cylinders would be capable of making more power because it will have more valve area. Valve area is very important in flow and flow is very important in making power.
That's why no Corvette in the last 45 or so years has had anything but a V8.
Larry
code5coupe
:seeya
Old Sep 8, 2003 | 06:04 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
5 & 7 being next to each other is a problem for several reasons. A few off the top of my head, is trying to feed them with a single intake duct can't be done effectively, since 5 will steal air from 7. On a TPI car, this affects the "tuning effect" also. And I'm sure there's issues with heating that corner of the engine up too much.
The newer order avoids this by firing two cylinders that are further apart.
Oh, and prior to that, as far as I know, ALL 90 degree V-8s had the SAME FIRING ORDER. They just numbered the cylinders differently.
My Ford 5.0 HO is special though. It's cam is backwards basically, so it's firing order is a mirrored image of that.
To Piston fire sequence ?
Old Sep 8, 2003 | 08:48 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
All small blocks, the same firing order. Right? Wrong?
tony
Old Sep 8, 2003 | 09:20 PM
neverendingproject's Avatar
neverendingproject
Default Re: Piston fire sequence ? (oldace84)
nascar has been using several different firing orders on their chevy engines for years... there are several different ones , although i dont know them off the top of my head. supposedly , a gain of as much as 10 horsepower can be found by doing this. although i dont believe the cost of a custom ground cam would justify doing it to a street car.
ok, just looked it up. b.t.w. its in the october issue of super chevy. there are 7 others that have been used. supposedly , reher-morrison has found the 1-8-7-3-6-5-4-2 gives the actual 10hp gain & also stated that reliability is increased.
[Modified by neverendingproject, 2:39 AM 9/9/2003]
[Modified by neverendingproject, 2:41 AM 9/9/2003]
Old Sep 8, 2003 | 11:48 PM
Curveit's Avatar
Curveit
The 4-stroke cycle might be easier to remember as..... Suck-Squeeze-Bang and Blow. I learned that as a kid. :D
