Weird idle problem
Old Sep 5, 2003 | 11:53 PM
RichAshley-Black99's Avatar
RichAshley-Black99
Default Weird idle problem
I had the the base plenium and runners off awhile back and cleaned it all up replaced the gaskets etc etc, I did not move or mess with the tps, when Im driving it seems to get stuck and wants to idle around 1000 to 1100 rpm when stopped at a light or whatever if I tap the gas pedel it goes back down to around 600 or 700 rpm where it normally did before it will stay untill I take off and then I have to tap the pedal to get it back down to normal idle. I took the trottle body off last weekend and checked it out it looked alright put it back on and the same problem any ideas??? :cuss
Old Sep 6, 2003 | 12:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Weird idle problem (AshleyRL-87Conv)
Check how much play there is in the throttle shaft bore.
The throttle plates and or shaft may be binding.
:cheers:
Old Sep 6, 2003 | 12:28 AM
nobodyunknown's Avatar
nobodyunknown
I suggest to retorque everything you replaced.Im thinking vacume leak
Old Sep 6, 2003 | 08:48 AM
Sam Lam's Avatar
Sam Lam
Sounds like somethig is in a "bind" and you are able to correct this with a tap on the accelerator. Look at your throttle cables and make sure they are located correctly and operate in a smooth manner! Good luck!
Old Sep 6, 2003 | 10:36 AM
MtlSphere's Avatar
MtlSphere
Default Re: Weird idle problem (Sam Lam)
:iagree:
WD-40
:seeya
Old Sep 6, 2003 | 11:25 AM
Caboboy's Avatar
Caboboy
Rich, there's definately something binding in there. I'd shoot some liquid silicone on the TB shaft, the linkage, and the cable. :cheers:
Old Sep 6, 2003 | 06:20 PM
RichAshley-Black99
Default Re: Weird idle problem (Caboboy)
Thanks guys Im about to go out and take another look :cheers: :cheers:
To Weird idle problem
