Problem from the lower temp switch and new harness swap.
Old Sep 8, 2003 | 12:49 AM
gpagaduan's Avatar
gpagaduan
Default Problem from the lower temp switch and new harness swap.
Did the lower temperature switch and harness swap tonight. Did the lower thermostat swap a few weeks earlier. Both fans seem to come on at a lower temperature as advertised but I'm not getting a temperature reading from my dash gauge. I didn't touch anything tonight except swapping out the switch, splicing into the relay harness, and adding about 1 1/2 gallons of coolant that I lost when I pulled the old switch. I did a long test drive to get the car up to temperature but the gauge didn't budge. The coolant temperature sensor and harneess are 4 months new and I'm not getting any trouble codes. Any ideas?
Old Sep 8, 2003 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Re: Problem from the lower temp switch and new harness swap. (gpagaduan)
Not sure about your 90 but my 86 has a temp gauge sending unit on pas. side between #6 and #8. Check for connection there.
Good Luck !!
[Modified by AGENT 86, 5:46 AM 9/8/2003]
Old Sep 8, 2003 | 09:30 AM
STANGKLLER's Avatar
STANGKLLER
Default Re: Problem from the lower temp switch and new harness swap. (AGENT 86)
:iagree: My 91" has the same set-up
Old Sep 8, 2003 | 10:30 AM
gpagaduan's Avatar
gpagaduan
Ok...now I really need some clarification. I thought between the #6and#8 on the 90 is the switch. Does it also act as the sending unit too? If so, am I supposed to take the original wire and splice into the new harness into for the temp gauge to operate?
Old Sep 8, 2003 | 10:57 AM
SunCr's Avatar
SunCr
Left side between #1 & # 3 is the fan switch; Right side between #6 & #8 is the gauge switch for a '90.
Old Sep 8, 2003 | 12:02 PM
ToniH's Avatar
ToniH
Default Re: Problem from the lower temp switch and new harness swap. (SunCr)
There was special instructions for 90 and 91's only included with my low temp switch. Anyway, in my car (91) there is no switch on the driver side. The hole for the switch is there anyway, it is just plugged.
So, do not touch the temp gauge sender on the passenger side, little late for that though. So, I suggest you return it to the state it was before you started.
Then read the instructions carefully once more. The switch should be installed to the drivers side cylinder head (between #1 and #3 like SunCr said). Then you splice the harness wires to the fan relay wires. The relays are located on the end of the radiator shroud. You should splice one of the harness wires to a relays blue with black or white striped wire and repeat this with the other relay.
If you don't have the instructions contact http://www.madvet.com
Good luck,
ToniH
Old Sep 8, 2003 | 03:05 PM
gpagaduan's Avatar
gpagaduan
Default Re: Problem from the lower temp switch and new harness swap. (ToniH)
So, for the 90 and 91 are you saying there is no fan switch to replace? And that I'm just supposed to use the new switch in the unused hole between 1 and 3? If that's the case, what has been controling the fans without the switch...the ECM? I thought the sender was controlling the fans and that's why I replaced it with the new switch.
[Modified by gpagaduan, 3:19 PM 9/8/2003]
Old Sep 8, 2003 | 06:01 PM
SunCr's Avatar
SunCr
If you have the dual fans behind the radiator, I'm pretty sure they are controlled by the ECM which grounds the circuit based on inputs from the coolant temp switch (under the throttle body), the a/c pressure switch, and the speedo signal from the VSS. I don't have access to a '90 schematic, but generally, you don't take the ECM out of the picture, you simply splice into the ground side of the fan relay (which is what the ECM controls). Then, the switch you add provides another path to ground when the switch closes. Use the vacant or plugged hole on the driver's side cylinder head for the switch.
Old Sep 8, 2003 | 06:48 PM
gpagaduan's Avatar
gpagaduan
Thanks for the clarification SunCr. That clears up everything. Now, is there a tool to remove the plug or does it just pull out?
Old Sep 8, 2003 | 07:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The earlier L98s without the aux fan option also had the aux fan switch hole plugged.
From what I've read here it can be a real issue to remove that plug. I believe several guys have machined a hardened steel stock to fit. If that doesn't work you may need to take it to a shop to have the plug removed and the new switch installed.
To Problem from the lower temp switch and new harness swap.
