Shifter indicator needle?
Old Sep 8, 2003 | 02:29 PM
The13Bats's Avatar
The13Bats
Default Shifter indicator needle?
I know how what it's hooked to on stock c3 but before I pull up the center console what is the shifter needle that tells you which gear you're in hook to?
thanks,
C.
Old Sep 8, 2003 | 05:20 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Shifter indicator needle? (The13Bats)
It's just a piece of plastic that slides inside the shift indicator window. When you pull the console up, the needle should stay with the console. There is a "U" on it that fits into a pin on the shifter itself.
Old Sep 8, 2003 | 05:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Shifter indicator needle? (Mr Mojo)
As MrMojo said the shift indicator U should fit over the pin from the side of the shifter.
You don't need to remove the shifter consol, you only need to lift the consol a little, just enough to move the shifter enough to position the pin under the U. It may take a copla tries but not a difficult task.
To Shifter indicator needle?
