Suspect O2 Sensor Bad
Old Sep 9, 2003 | 02:08 PM
CAJUN C4's Avatar
CAJUN C4
Default Suspect O2 Sensor Bad
Anyone have an Oxygen Sensor go out.? What were your symptoms, codes set etc.
Old Sep 9, 2003 | 03:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Suspect O2 Sensor Bad (CAJUN C4)
A faulty O2 sensor can throw a code 13.
To see if your ECM is going and staying in closed loop, use the method on my site (link in my sig. below). If all is ok then both the O2 sensor and the coolant temp sensor are fine.
Old Sep 9, 2003 | 03:11 PM
Fast_vette89's Avatar
Fast_vette89
Default Re: Suspect O2 Sensor Bad (65Z01)
To all fellow 1 wire sorry azz o2 equipped sensor guys. GO TO A 3 or even better 4 wire sensor. :)
Old Sep 9, 2003 | 05:49 PM
6spd's Avatar
6spd
Default Re: Suspect O2 Sensor Bad (Fast_vette89)
i second that
Old Sep 9, 2003 | 05:50 PM
scorp508's Avatar
scorp508
Default Re: Suspect O2 Sensor Bad (6spd)
Put your foor to the floor. If car seems ok then, O2 sensor is bad. (O2 sensor is ignored in WOT mode)
Old Sep 9, 2003 | 06:47 PM
Corvettaholic's Avatar
Corvettaholic
Default Re: Suspect O2 Sensor Bad (scorp508)
does an 85 have one or two O2 sensors? i see one on the drivers side manifold plenty fine, but I haven't looked for the other one. I had my mechanic replace one (i think there is only one) and ever since then i've gotten atrocious gas mileage and part-throttle problems. maybe he dropped it...
Old Sep 9, 2003 | 11:14 PM
Sam Lam's Avatar
Sam Lam
Default Re: Suspect O2 Sensor Bad (Corvettaholic)
My 89 L98 has one oxygen sensor and this is located on the drivers side of the exhaust manifold. The O2 sensor should be changed out at 40000 miles for best performance. Did your mechanic replace the sensor with a GM part? I have tried aftermarket parts for emissions and have not had good luck with them. My best results have been when using OEM parts. Hope this is helpful!
Old Sep 9, 2003 | 11:16 PM
scorp508's Avatar
scorp508
Default Re: Suspect O2 Sensor Bad (Sam Lam)
L98 = 1 one-wire oxygen sensor
Old Sep 10, 2003 | 03:15 PM
Nathan Plemons's Avatar
Nathan Plemons
3 wire works fine. Not real sure of the benefit of a 4 wire, there's nothing to connect the 4th wire to.
To Suspect O2 Sensor Bad
