zf drain plug
Old Sep 9, 2003 | 04:18 PM
1989redvette's Avatar
1989redvette
Default zf drain plug
i can't seem to get my drain plug out....i'm afraid of breaking the case ... :nonod: anybody got some solutions... i have tried alot of things even sprayed it with blaster and let it sit ...still seems frozen really tight :banghead: i really want to change my fluid but i don't want to break the case or strip it out :cry
Old Sep 9, 2003 | 04:56 PM
cire96's Avatar
cire96
Default Re: zf drain plug (1989redvette)
Assuming that you're using a hex wrench / socket combination, try an impact wrench. It's amazing how often one will break loose a very stubborn bolt that might otherwise break.
On the other hand, unless the plug has been scrunched by bottoming out the car, I can't imagine that a plug with upteen quarts of oil sitting over it is really all that stuck. Bear in mind that the plug is a tapered thread. Therfore it might take a pretty good tug to get it loose.
One final thought, you could pump out the oil using the same plastic gallon bottle pump rig that most use to empty the differential.
Good luck. Cire96
Old Sep 9, 2003 | 05:40 PM
bogus's Avatar
bogus
uh, the torque spec for the plug is like 100 ft lbs.
so yes, it is tight. super tight...
Old Sep 9, 2003 | 05:42 PM
JasonL's Avatar
JasonL
Default Re: zf drain plug (bogus)
Actually the spec is only 25 lb-ft or so...
Now how much they tighten it at the factory, I have no clue! I think they hire a gorilla to install the plugs.
Old Sep 9, 2003 | 06:37 PM
1989redvette
Default Re: zf drain plug (JasonL)
i'm no wuss but i have had a 2 foot breaker bar on it with my feet braced and pulling with everything . i mean this thing is tight...it appears not to be crunched from bottoming out either ...so nobody has broke a case or anything??
thanks chuck :cheers:
To zf drain plug
