Spark Plug change - 96 - LT4
Old Sep 9, 2003 | 06:09 PM
dkw's Avatar
dkw
Default Spark Plug change - 96 - LT4
My friend wants me to help him change the spark plugs on his 96 - LT4. While we have both done other years neither of us have changed plugs on a LT4. Is there anything anyone can tell us in advance re: the difficulty or ease when it comes to this motor? Any special tips, tools, recommendations??
Thanks.
Old Sep 9, 2003 | 06:37 PM
GS919's Avatar
GS919
Default Re: Spark Plug change - 96 - LT4 (dkw)
It is a tight squeeze. It helps to remove the inner fender liner pieces between the wheel and the engine. Just a few bolts to undo and it gives you better access. I would suggest having different sized socket extensions and a swivel adapter. Using a short piece of fuel line pushed over the plug end is a great help in getting the new plugs started on the threads. Not a bad job, just is time consuming as there is a lot of stuff in the way. :cheers:
