HELP! Removable top squeaks/rattles bad!
Old Sep 10, 2003 | 11:31 PM
95_6spdvette's Avatar
95_6spdvette
Default HELP! Removable top squeaks/rattles bad!
Ok my top has been sqeaking and rattling really bad lately? I think this may be common for these cars but not for sure. May be the brackets up front where it bolts in. Does anyone have suggestions on how to get rid of this or will have to live with it?
Old Sep 11, 2003 | 03:20 AM
Larrym96815's Avatar
Larrym96815
Default Re: HELP! Removable top squeaks/rattles bad! (95_6spdvette)
Mine never rattled but it did squeek. I took it off and put a thin coat of vaseline all around the contact points and on the bolt threads. That stopped my squeeks. Rattles seem like one of the bolts may just be loose.
Where is Mitchell IN? I use to hang around Angola.
Aloha,
Larry
[Modified by Larry Mackey, 9:21 PM 9/10/2003]
Old Sep 11, 2003 | 03:41 AM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Re: HELP! Removable top squeaks/rattles bad! (Larry Mackey)
Well I have some squeaks but they get flooded by the radio and the exhaust :nono: Im sure you've tried tightning the bolts but the Vaseline trick is new to me. I will try it for sure
Old Sep 11, 2003 | 10:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
MAD sells a 'Seal out Squeak for roof panels' #600-262 @ $12.99 for the set... added it to mine and noise gone, also used the 'Alignment doc' here in the forum to realign my top, that helped alot too..
Old Sep 11, 2003 | 10:40 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: HELP! Removable top squeaks/rattles bad! (vinnies87)
Check out this procedure to align the top. I did it and it took care of all the squeaks and rattles (and one of the rain leaks).
http://forums.corvetteforum.com/zerothread?id=406769
Old Sep 11, 2003 | 12:54 PM
JCAIRE2's Avatar
JCAIRE2
I like this procedure as well, but I'm a little biased :D
https://www.corvetteforum.com/techti...=200&TopicID=2
Old Sep 11, 2003 | 01:30 PM
Dave C. '04 Z06's Avatar
Dave C. '04 Z06
Default Re: HELP! Removable top squeaks/rattles bad! (JCAIRE2)
I think that I would recommend if you follow that procedure to make absolutely sure that your car is on a level surface. If you align it while the car is crooked, it will stay crooked.
Make sure the original reason you couldn't get the thing on was not because the car was on an uneven surface.
The only reason I say this is because I once watched for a 1/2 hour while my friend fought with his top, only to find out the left rear tire was on a bump, so the car flexed enough to cause the top to not align right. We moved the car forward a foot and the top went right on.
Old Sep 11, 2003 | 07:49 PM
Shawn84&92's Avatar
Shawn84&92
Default Re: HELP! Removable top squeaks/rattles bad! (Dave C. '97 Z28)
My 84 used to rattle, and after months of trying to find it, it ended up being the rear bolts that hold the catch to the targa bar under the trim panel. They were loose, so it rattled.
Shawn
Old Sep 11, 2003 | 09:51 PM
RED92LT1's Avatar
RED92LT1
Mine did the same thing. Turned out to be the brackets up front on the top, they were loose. So I took the top off and tightened them ... no more rattles or squeaks at all. :)
Took a 1200 mile trip last week and it sounded like a new car.
Brian
Old Sep 11, 2003 | 11:17 PM
95_6spdvette
Thanks everybody and I'm gonna try it this weekend! Once again thanks for all the help!
Old Sep 12, 2003 | 07:44 AM
JB666's Avatar
JB666
Default Re: HELP! Removable top squeaks/rattles bad! (RED92LT1)
Brian
Ditto, mine were lose, and I didnt' know it. The squeaks were insane.... So, I took the top off, tightened those up,and away they went!!! :cheers:
To HELP! Removable top squeaks/rattles bad!
