My antenna on my 94 goes up and down but doesn't go all the way down. Is it the mast that should be replaced? Has anyone had this problem? What was the cause.
How do I contact Jeff Kopp, Carfan 18, to get a price on parts. How are forum members located? Like if I wanted to get a forum members email, how would I do that?
Re: Antenna Issue and how to contact Jeff (Thomastp)
Jeff Kopp has moved into management. Chris May has taken his place, good guy to deal with. 1-800-728-8267.
As far as locating a members e-mail, go to search, type in there handle, and search either recent posts, or archieve posts. Then click on that persons handle. You'll get they're info.
I had the same problem. I didn't need to replace the mast. The mast may just need a good cleaning. I sprayed some electrical cleaner on the mast and then wiped it down really well. If you have any spots that are rough, you may want to take some high grit (2000, 4000, 8000) sandpaper and wet sand it to smooth out those spots. I did that and then used a little metal polish and the mast now goes all the way down. Before, the very top would not go in without a little help. It was getting caught on all the dirt and on a couple of rough spots.
