Cut lids
Old Sep 9, 2003 | 12:35 AM
OneRedLT4's Avatar
OneRedLT4
Default Cut lids
Been reading through a bunch of threads and I see a lot of "cut lid"s referring to (I'm assuming) the housing for the air cleaner. What is this supposed to be helping with, and does anyone have pics as a reference incase I decide to make that first incision :eek: . The extended service contract is up, checkbook balance is down, so I'm looking for things I can do myself. Thanks.
Old Sep 9, 2003 | 12:42 AM
subman's Avatar
subman
Default Re: Cut lids (OneRedLT4)
This is what mine looks like in my 91 L98
Not hard to do, just a little time consuming to do it clean
Good luck
[Modified by subman, 10:43 PM 9/8/2003]
Old Sep 9, 2003 | 12:47 AM
hngacurv's Avatar
hngacurv
A cut airlid is easy to do. I took the air cleaner off my air filter and with a cutoff tool cut out the front of it. I used one of the 2 bends as a guide. I left enough to hold the air filter in place when I reinstalled it. [IMG][/IMG]
Old Sep 9, 2003 | 01:23 AM
BowTieBlood's Avatar
BowTieBlood
All you gotta do is remove the metal piece from the car............. drill or punch the riveted pieces, that removes the top lair..... then use a dremel or something of the sort to cut out the louvres or whatever you want to call them so you have one big open hole.......... just dont cut too far so the filter stills tays in place. :cheers:
Old Sep 9, 2003 | 07:55 AM
MtlSphere's Avatar
MtlSphere
Default Re: Cut lids (subman)
Good luck
Overdue for a K&N! :seeya
Old Sep 9, 2003 | 08:23 AM
Jeffmete's Avatar
Jeffmete
Mine looks similar to the 91 pic, except I have a verticle band, not horizontal. Took about 5 minutes with a pair of tin snips.
Old Sep 9, 2003 | 10:20 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default Re: Cut lids (jhughes2101)
The real question here needs to be does it REALLY do anything to help performance?
-Rick
Old Sep 9, 2003 | 10:42 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: Cut lids (cicch95)
Good question on a stock filter system...
Old Sep 11, 2003 | 05:50 PM
OneRedLT4's Avatar
OneRedLT4
Default Re: Cut lids (vinnies87)
Thanks guys, a picture's worth a thousand words...or in this case, many-a posts. :D
Now, where did I put that cut off wheel... :smash:
Old Sep 11, 2003 | 06:14 PM
1MoorTym's Avatar
1MoorTym
-Rick
Couldn't hurt. Probably ranks higher on the feel good scale than the performance scale.
Old Sep 11, 2003 | 07:26 PM
JCAIRE2's Avatar
JCAIRE2
A clean paper filter and K&N filter will flow the same. The K&N's advantage is being able to clean it, and it flows more when it's dirty than a paper filter will flow when dirty.
Old Sep 11, 2003 | 07:29 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Cut lids (1MoorTym)
-Rick
:iagree:
Mr Mojo's Avatar
Mr Mojo
Default Re: Cut lids (JCAIRE2)
Good question on a stock filter system... A clean paper filter and K&N filter will flow the same. The K&N's advantage is being able to clean it, and it flows more when it's dirty than a paper filter will flow when dirty.
:iagree:
Old Sep 11, 2003 | 07:57 PM
crheinish's Avatar
crheinish
I used tin snips and installed a K&N air filter at the same time. :cheers:
Old Sep 11, 2003 | 10:42 PM
z51spdr's Avatar
z51spdr
I don't know if it actually helps a substantial amount performance wise, but when I but my lid open I installed a K&N as well and cut the screen out of the MAF. When i started the engine up afterwards, you can actually hear the engine sucking air in.
Old Sep 12, 2003 | 01:45 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Re: Cut lids (z51spdr)
I did the cut-lid with the MAF screens removed...didn't really feel a difference....but it may be there...
Old Sep 12, 2003 | 01:55 AM
87NassauBlue's Avatar
87NassauBlue
You can buy a lid that is already open or cut your stock one. You want to cut it as big as you can and still have it retain the filter well. The performance piece is reducing air restriction. The K&N filter is supposed to have less restriction. You can use a zizz wheel or a nibbler to cut it. The nibbler will make the cleanest cut, but watch out for those cuttings, they are like little needles. On the C4's that have mass air flow sensors, you can cut out the screens. They also make a smooth air connector to replace the original ribbed one on the early C4's.
To Cut lids
Old Sep 12, 2003 | 02:10 AM
Dan Parker '96's Avatar
Dan Parker '96
I'm sure the cut lid does nothing but look better (I've got the setup BTW).
Actually, after looking at the stock setup I think the stock lid (with the angled vanes) may be a better setup.
The raised portions of the hood look like a "long distance" version of the classic "ram air" setup used on many '60's (and currently NASCAR) intake systems. They use the high pressure area of the lower windshield to help with the intake charge.
Although the 'Vette has a pretty long path from the base of the windshield to the intake (plus the windshield wipers are in the way) the angled vanes of the stock lid look like they were designed to take advantage of the flow.
Regardless, you won't find any advantage from the K&N over a clean, stock paper filter concerning flow (I run the K&N). The only advantage for the K&N is the "convenience" of a reusable filter element.
Hmmm... after reading my own statements I think buying a half dozen regular filters and slapping on the original lid is in my future.
Old Sep 12, 2003 | 04:46 AM
smacko's Avatar
smacko
:iagree: Your sig say you already run a K&N so the consensus seems to be it, combined with an open lid is worth around the 10-12HP mark at flywheel.
MORE is quoted according to the aftermarket mags! I did it and other things and can't say I notice any difference but I have no doubt it HAS increased HP and even in theory that sits well with me :)
The lid is surprisingly thick (alloy I think) and I used a brand new cutting disk from a cheap shop on my angle grinder, and WORE IT OUT before I was done! Then I wacked the modified lid onto bench grinder and smoothed off edges, mostly so I wouldn't cut myself when I took out filter next, then spray painted it black before re-installing it.
Hope that helps :smash:
Old Sep 12, 2003 | 07:32 AM
OneRedLT4's Avatar
OneRedLT4
MAF? What's that? Read that a lot too, but couldn't figure it out.
