mayday, lose harmonic position ,mayday
Old Sep 12, 2003 | 05:05 PM
korvettek's Avatar
korvettek
Default mayday, lose harmonic position ,mayday
im replacing my opti and water pump.i didnt mark my harmonic balancer is there any mark or way to tell or does it even matter. :confused:
Old Sep 12, 2003 | 05:29 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: mayday, lose harmonic position ,mayday (korvettek)
Did you just remove the dampener from the hub by removing the 3 bolts?? If this is the case it will only go on one way, the holes are not evenly spaced.
Old Sep 12, 2003 | 11:18 PM
korvettek's Avatar
korvettek
Default Re: mayday, lose harmonic position ,mayday (Nathan Plemons)
yes i did ,i removed the 3 bolts .i didnt know it would only go on one way i dint try to put it back on yet .thank you very much. :cheers:
To mayday, lose harmonic position ,mayday
