power steering whine
Old Sep 13, 2003 | 03:47 AM
larryfs's Avatar
larryfs
Default power steering whine
after a track session or 2 my power steering whines real bad. very noisy.
every thing works fine, but the whining is a sure indication of a problem to come. I havn't blow anyhoses like my fellow LT4 owners, but what is causing the whining?
I'm thinking if I go synthetic, it'll start to leak from the seals.
anyone solve the whine, or go syntheic?
Old Sep 13, 2003 | 04:22 AM
Q1KSLVR's Avatar
Q1KSLVR
Default Re: power steering whine (larryfs)
:boxing Your P/S system gets a workout just like anything else if you race it...:boxing
As the fluid gets hot, it thins and cavitates. Air foaming in the pump will make noise.
I would consider adding a P/S fluid cooler and changing the fluid as it may be burnt and lost it's viscosity.
I would still go with the Dino fluid though... :thumbs:
Old Sep 13, 2003 | 10:15 AM
larryfs's Avatar
larryfs
Default Re: power steering whine (Q1KSLVR)
the LT4 has a cooler from the factory
Old Sep 13, 2003 | 12:18 PM
superlund's Avatar
superlund
Try the cold climate PS fluid from GM, the C4 autox guys use it. I've been using it without problems or whine... Has to do with the additive package it contains. I'd order it from Jeff Kopp / Superior as its about $15 a pint at the local GM dealer. May be too late for your pump, how many miles?
Old Sep 13, 2003 | 12:43 PM
larryfs's Avatar
larryfs
Default Re: power steering whine (superlund)
20,000 miles on the car, and after the car cools off, the whine goes away.
it must be the fluid overheating, and the cooler is too small for the application.
I would think the cold climate stuff wouldn't be able to take the excessive heat :confused:
Old Sep 13, 2003 | 02:53 PM
larryfs's Avatar
larryfs
I read up on that cold climate stuff. seems only to be applicable to 94 and eariler. however I still have to check if the 96 cars came with it.
Old Sep 13, 2003 | 05:48 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
You put it under alot of stress.
Need a cooler for steering sys.
tony
Old Sep 13, 2003 | 10:03 PM
larryfs's Avatar
larryfs
Default Re: power steering whine (oldace84)
tony,
read my post above. it has a factory cooler. :smash:
I think the answer is synthetics
To power steering whine
